Old 02-10-2009, 11:10 AM   #1
Tim R
Spindle help
Hi I am new to this site and I have a question about lowering spindles . I got a set of 2 in drop spindles from a friend and was told they were off of a 72 chevy truck . I installed them and went to attach the outer tie rods and the hole in the tie rod attaching point is way to big for my tie rods. I went to the parts store and we pulled a couple of tie rods and the only ones that i saw that would fit were from a 73 chevy but the shaft was to big for the adjusting sleeve . They didnt have the 72 tie rods . Can anyone tell me the differences between the tie rod size . They are DJM spindles Thanks Tim
Tim R is offline   Reply With Quote
Old 02-10-2009, 11:20 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Spindle help
You have 73-87 spindles. An easy solution is to convert to 73-87 steeping linkage, adjuster sleeves, and tie rod ends.
Old 02-10-2009, 11:29 AM   #3
Tim R
Re: Spindle help
But wouldnt the inner tie rods be to big for the hole in the drag link they are the same size as the 72 outers or can i machine the drag link to accept the bigger inner tie rods? Thanks Tim
Old 02-10-2009, 11:42 AM   #4
Tx Firefighter
Re: Spindle help
I always just run 73-87 from side to side, center link and all.
Old 02-10-2009, 12:47 PM   #5
Elephanthead
Re: Spindle help
One of the site vendors sells a sleeve that is a different size on both ends, if you want to do as little work as possible. It is made for what you are doing.
Elephanthead is offline   Reply With Quote
