Old 02-10-2009, 04:53 PM   #1
cstm68
cstm68's Avatar
rear disc calipers?
who here is using the cadilac siville rear e-brake calipers? what year cady do they come off? also what e-brake cables do i need? can i use my stock cables?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 02-10-2009, 05:01 PM   #2
cstm68
cstm68's Avatar
Re: rear disc calipers?
ooops i didnt mean to post this in the projects and builds section. i ment to post it on the regular message board. could a mod please move this?
Old 02-11-2009, 02:42 AM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Its not seville only, its the big cars with 5x5 pattern & have rear discs
I think mine are from a 76 or something, I dont really remember
I havent gotten them on yet, but I dont think the stock E-brake cable will work, you need to adapt from the stock one on the truck to the ones on the disc calipers
Maybe someone else has more input
Here is a thread with the years & models that had 5x5
http://67-72chevytrucks.com/vboard/s...d.php?t=234769
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-11-2009, 11:16 PM   #4
cstm68
cstm68's Avatar
what 6 on 5.5 rotors will work with these calipers?
Old 02-12-2009, 10:30 AM   #5
Shane
Shane's Avatar
Cadillac Seville '77-'79 model years use 5 x 5" rotors ... I am using this model caliper as well. You will need to do some machine work on the axle flanges as this is not a bolt-on mod.
You will also need to make / fab brackets to mount the caliper as the caddy mounts will not work.
Shane is offline   Reply With Quote
Old 02-12-2009, 11:58 PM   #6
cstm68
cstm68's Avatar
oops i ment what 6 lug 6on 5.5 rotors will work?
Old 02-13-2009, 06:44 PM   #7
Sir Fisher
Sir Fisher's Avatar
on my rear axle i'm using 76-78 eldorado rear calipers and 92 Astro Van all wheel drive front rotors 6 on 5.5; here a pic.
1970 Chevy K20 Custom Camper
1996 Chevy Impala SS
2008 Chevy Avalanche LT3
2003 Honda Accord EX
2001 Hewes Redfisher 16 Fighting Lady Yellow
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118
Sir Fisher is offline   Reply With Quote
Old 02-14-2009, 04:46 PM   #8
70clone
70clone's Avatar
so astro vans awd are 6 lugs if so that is sweet
70clone is offline   Reply With Quote
Old 02-19-2009, 12:24 AM   #9
cstm68
cstm68's Avatar
so i tried and astro rotor but it wouldnt fit over the hub,
what si the best way to convert to rear disc with and e brake?
Old 02-19-2009, 12:46 AM   #10
powerbench
powerbench's Avatar
hey sir fisher, how do the calipers fit in a 15 inch wheel ..any clearance problems...i just bought a set of backing plates , on the off chance it will work on my 12 bolt.
powerbench is offline   Reply With Quote
Old 02-19-2009, 07:27 AM   #11
Chevy4Life
Chevy4Life's Avatar
I was going to ask if the astro rotors fit over the hubs. He probably turned them down if you tried them and they didn't fit. I used 88 4x4 front rotors and had to turn the hubs down. Most guys have them done at a machine shop. I had a bare frame, so I used a BIG drill on the yoke nut and a grinder on the hub.
I wonder if the astro and 4x4 rotors are the same. It looks like they have the bigger lug holes like the 4x4, because GM went to a bigger stud and the stud is pressed into them.
Jay
Chevy4Life is offline   Reply With Quote
Old 02-19-2009, 07:30 AM   #12
Chevy4Life
Chevy4Life's Avatar
I'm on 15" rollers right now and they fit fine. They aren't stockers just cheap chrome wheels.
Jay
Old 02-19-2009, 11:30 AM   #13
Sir Fisher
Sir Fisher's Avatar
they should work fine... but don't quote me... i tried it with a 16" wheel and it fits fine with room to spare.
Old 02-19-2009, 02:12 PM   #14
Sir Fisher
Sir Fisher's Avatar
i'm so sorry guys; i gave wrong information... i double checked with my informant and for 6 lugs it's a 92 1/2 ton p/u 4X4... the astro vans are 5 lugs.
Old 02-19-2009, 10:33 PM   #15
cstm68
cstm68's Avatar
are theos off the front? and do they fit over the hub?
Old 02-20-2009, 12:50 AM   #16
Sir Fisher
Sir Fisher's Avatar
they are off the front of a 92 K1500. for my rear 12 bolt and yes, it fits over the hub.
Old 02-20-2009, 01:10 AM   #17
powerbench
powerbench's Avatar
Do the Eldorado calipers have built in e-brake provisions..Do you have a pic from the top looking down at the disc and caliper...sorry to be a pain , just haven't been able to find caliper cores as of yet ,and i'm just tryin to make sure i'll have the space to fit these in my rims
Old 02-20-2009, 11:00 AM   #18
Sir Fisher
Sir Fisher's Avatar
hope this shows what you're looking for.
Old 02-20-2009, 11:04 AM   #19
Sir Fisher
Sir Fisher's Avatar
Question Re: rear disc calipers?
forgot to post the pics...
Old 02-20-2009, 11:05 AM   #20
powerbench
powerbench's Avatar
i think it didn"t take your attachment
Old 02-20-2009, 09:03 PM   #21
powerbench
powerbench's Avatar
oh there they are. Thanks for the pics...i just went out and measured the distance from the face of the axle to the edge of the mounting surface for the backing plate, just as i thought , it's to close to the back of the rim...then i measured the bolt holes for it to mount, they aren't even the same spacing..now i have to decide to chop up this backing plate and make it work , or keep searching.....thanks again
Old 02-20-2009, 09:09 PM   #22
Chevy4Life
Chevy4Life's Avatar
That's good to know. I need to check my paperwork I may have used 90 or 91 Blazer fronts. hmmm
Jay
