HELP Please 85 GMC body fit on 74 chevy frame
Hi im pretty sure this would fit but i just found a nice 85 GMC cab,dog house and bed for 200 bucks... this will bolit right up to me 74 chevy4x4 frame right with out any mods? just want make sure befor i make the drive to get this body.. Is there any thing to look for on the cab to watch out for? This is my first time doing a swap with a body.
Also whats the difference between these years on the wirings meaning how do i find out witch wire is what? thanks Mark
04 Chevy Duramax LLY crewcab 4X4 Built ATS Allison Upgrades ![]() 75 chevy 3/4 ton 4x4 its got a built 350 with dana 44 and a lift. Last edited by onesmokinduramax; 02-10-2009 at 08:10 PM. |
Re: HELP Please 85 GMC body fit on 74 chevy frame
Right now i have a 84 body on a 73 2wd frame without any problems at all. so i would say you would have no problems, but maybe there is something different with the 4x4s. And look for rust cab corners, rockers, floors, and on my cab i have rust on my front window seal area in which i dont know how i an going to fix.
Ok i thought it would. Only place the guy said there was rust on the cab was a few small holes in the rocker.. The bed has a big dent in it by the tail light but i dont think that is a big deal.. The cab inside not bad shape its alot better then what i have! but it would need a new seat
Heres a few pic
04 Chevy Duramax LLY crewcab 4X4 Built ATS Allison Upgrades ![]() 75 chevy 3/4 ton 4x4 its got a built 350 with dana 44 and a lift. |
Robert Olson Transport
![]() Join Date: Oct 2002
the only issue is you have to use the rubber body moounts that work with the frame IIRC.I did this with a 76 frame and an 81 cab. you may want to shoot a PM to CaptKaos as he is our resident expert there are other things if you are going to use the nose of a 73-80 on and 81-87 cab tho do you need that info?
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! Last edited by old Rusty C10; 02-11-2009 at 11:59 AM. |
I thought you used cab mounts for the year of cab? I may be wrong, its been a while. I know they aren't the same though!
1976 Chevy 1/2T 2wd SWB ![]() ![]() 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com ![]() |
i used mounts for the frame not the cab, and i had no problems.
I took a 86 4x4 body and put it on a 77 2wd frame and used the body mounts of the 77.
Its Kool to be a square ![]() 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers ![]() ![]() --- ![]() ![]() ![]() |
i know that 4 wheel drives have a higher center hump. theres a high hump and a short hump and most of the high humps been on 4X4's
http://67-72chevytrucks.com/vboard/group.php?groupid=37 73 C10 Fleetside ![]() If it ain't a Chevy it's foreign ![]() http://hotridesmag.com/ |
#9 | |
Living Legend
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia.. ![]() project is temporarily on pause again... Thankyou wonderfull economy.. check it out Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap East Ok meet East Ok date Tony ![]() |
Well i picked up the truck to day. I got there and he let the frame go with it. Its a 2 wheel drive frame so i can not use it. But got a question with this being a 2wd will i have to replace the hump in the cab to fit my 4x4 frame? I will be puting a 3 inch body lift on it..
By the way the cab and dog house is in great shape lot better then the pic shows! could not pass the deal up that he give me.
![]() Join Date: Jun 2007
Since the high hump floor is just for clearance of the transfer case and you plan to use a 3" body lift I see no problems since 3" should give you plenty of clearance. You'll just have to cut the hole for your transfer case shift lever.
If you decide to replace the rubber mounts in the frame be sure to buy them for the year of frame, not the body. 81-87s are different than 73-80s. I'd suggest installing polyurethane ones. They are much better than the stock rubber ones and will last a lot longer. Good luck and be sure to post up pictures! ...Joe
I'm not speedin'! I'm qualifyin'! |
#12 | |
thinair
![]() Join Date: Jun 2004
#13 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Sorry I have been away for a shot time.
Everything posted is correct. Cab will work You MUST use at least a 1" Body lift to clear the trans/transfer You MUST use body bushings specific to the Frame not the body. All 73-87 body pans are identical, it is the frame mounts that changed.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#14 | |
Living Legend
#15 |
Im doing the swap now i got the old body off and the new cab just siting on the frame... I have looked on ebay and all over the web and cant find a body mount kit for my frame. can you tell me some where to get them? the frame is in the year 74-79. Also the old body did not have any body mount bushing at all just had a 3 in body lift in place. Is there any thing that i would need to buy with the body mount I have been working on it and just ran in to this issue.
Thanks Mark
#16 |
Living Legend
Summit sells them, brand name is energy suspension I believe local parts houses Cary to, around here anyways
#17 |
LMC carries the body mounts also.
One question for everyone doing the 73-81 frame with a 82-87 cab (or vice versa)... what are you all doing at the front bumper? I know the frame changed there for the different bumper and corresponding mounts.
1988 R2500 Crew Cab Immediate plans- get it running! Future plans- Rear disc swap & Hydroboost Dually conversion with shackle flip-n-switch 4x4 conversion with 52" springs Maybe some new body panels ![]() Who needs a car when they make crew cab trucks? |
#18 |
Living Legend
Mine will be custom.... But the bumper I'm using is off of a completely different vehicle also so I don't think that's of help to you
#19 | |
#20 |
#21 |
Diggin The SquareLife
talk about a thread being brought back to life!
#22 |
i just did a frame off on my 1980 GMC used mounts for year of frame also the VIN tag is in a diff location and the wipe switch you need to cut a new hole for that. and wiper arms from the 74 and also the the light switch need to relocate that's all if you are using the 74 dash and interior and nose from the 74
#23 | |
#24 |
Use 73 core support bushings and your 84 core support will work. Cut the horn off the frame and use the 84 bumper brackets.
#25 |
