BlahBlahBlah
Gear Venders OD, New never installed
Now that I finally got my panel home and am starting the process of putting her together Im having to make some final decisions on my drivetrain.
The biggest thing I decided is I wont be using my Gear Vendors Overdrive Unit now. So if I can get $2150.00 plus shipping out of it I will let it go. Thats a $445.00 savings. If not Ill just hang onto it. Its for a Chevy turbo 400. Gear Vendors part no.3DFS400A. You can see pictures and prices on their website, its the second one from the bottom of the page. http://www.gearvendors.com/hrgm3s.html It weighs almost 60lbs. I can only ship via UPS so if you're interested check the UPS shipping calculator. Shipped from a commercial address, zip code 98005. Sorry I don't need anything in trade. Thanks. Mark
… … … … … … … … ... … … … … … … … … … … … Last edited by CG; 02-10-2009 at 10:21 PM. |
Re: Gear Venders OD, New never installed
This would be perfect in the burb!!! Too bad I am so broke!!! ARGHHH!
Good Luck with the sale. Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
what a smoking deal. I paid $3300 candian$ for mine. increase of 5 - 8 mpg on the hwy
1972 GMC Sierra 1972 GMC Super Custom Suburban |
BlahBlahBlah
Most of it is still sealed in the original boxes unopened from when I purchased it. I did take a peek at a couple of things before I put them back in their boxes. Here is a pic I "borrowed" from the GV website. This is everything it comes with.
Probably too expensive of an item to sell in this economy, but TTT anyway.
What rear end gear was it purchased for?
BlahBlahBlah
I told them I was running. Caddy 500, turbo 400, 28 inch tall tires and either 3.73 or 4.10 rear gears. They took it from there.
Junior Member
Is there any transferrable warranty? If so when does it expire?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Can you find any paperwork that states which rear? I only ask because on the website it states that they set up the unit for the rear end gearing also. I am just trying to figure out if it would in fact work for us.
Shawn
for a possible buyer, all you need to do is call GV and tell them what your tire height is and your rear gears and they'll send you a coloured gear to replace (if needed to) the one installed (simple job replacing). your speedo will then be correct and they'll be able to tell you your final gear ratio with the GV.
CG did you know that the old caddys in the early 70's ran a rear end at 2:28. My 425 in the Burb had a 3:21 and with the GV installed it was now at. 2:89 (number came from GV). 70 mph at 1400 rpm on the I5 Hwy. Al.
1972 GMC Sierra 1972 GMC Super Custom Suburban Last edited by IAFF2407; 02-11-2009 at 12:34 PM. |
BlahBlahBlah
I have no idea on the warranty. Ill call GV and see what I can find out. Maybe they have the info on the interior gears they installed in it too.
Mark
Mark, in your GV where the speedo goes, the cap comes off (see your pic, the 1 1/4' circle) when you look inside, you will see the colored gear, (GV has them color coded) let me know the color and I'll look in my book and tell you what it is............
........or call GV, give them the serial # and they'll tell you on the spot. Al.
Active Member
![]() Join Date: May 2005
I'll take it!!
PM sent Jason
Cadillac Powered |
#13 |
BlahBlahBlah
Ok guys since Jayss109 came out and said he would take it he is the one that gets it. I dont think Im breaking any rules, I ran this past the mods for opinions first. Hopefully no one will have hurt feelings over it.
#14 |
Active Member
Mark thanks so much for the Gear Vendors Unit. Everything as advertised and real easy transaction. Now if I can figure out this rep thing, I'll send ya some!
Jason Very happy customer
Cadillac Powered |
#15 | |
BlahBlahBlah
Mark
… … … … … … … … ... … … … … … … … … … … … Last edited by CG; 02-24-2009 at 09:28 PM. |
