Old 02-10-2009, 09:51 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
headers..
dad bought me some new plug wires/pcv valve today at autozone..the guy talked him into the fact that headers increased performance gas mileage etc etc..
wats a good kind..
there any difference between 150$ autozone headers and the other brands, thanks!
John
1999 Toyota Tacoma 4x4
Old 02-10-2009, 10:08 PM   #2
jugernot
Life, Be In It.....
jugernot's Avatar
Re: headers..
Sanderson. These are the ones I have. Very well built. You know that have to be good if they are the only ones Early Classic Enterprise offers.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 02-10-2009, 10:15 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Re: headers..
Those might be out of the kids price range. I ran some $100 Flowtechs on the '72 I used to have and they worked/fit just fine.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-10-2009, 10:25 PM   #4
oldblue1968chevy
Re: headers..
what do those sandersons run...
rahter not spend over....200 or so really....is it ok to buy em used or new the best route?
are flowtechs the autozone brand?
whats some thigs to look for when buying, any kind of special coating thats a MUST HAVE.....what kind of metal is the best, or are they all steal, is there a stainless? thanks somebody point me in the best direction!
John
Old 02-10-2009, 10:37 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Re: headers..
Those Sandersons are $379 over at ECE. If I were in your shoes I'd be fixing the stuff that needs fixing first and worry about headers and stuff later. I know you have some leaks you gotta fix. JMHO.
Beat it to fit,
Old 02-10-2009, 11:28 PM   #6
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: headers..
Try not to take what an autozone guy says to heart... I cannot stand going there unless I have parts numbers in hand.
But, headers reduce back pressure, sacrificing low end torque for mid-high end power. Depending on your motor is to what effect it has on MPG.
texanidiot25 is offline   Reply With Quote
Old 02-11-2009, 01:20 AM   #7
Gray Ghost
Gray Ghost's Avatar
Re: headers..
I agree....I never buy anything there either....don't like their parts.
I am on the last set of headers I will buy for a truck. Used to not be a problem, but now keeping leaks to a low roar is virtually impossible.
If I had this one to do over I'd get a good set of Vette ram horns and call it a day.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 02-11-2009, 01:32 AM   #8
texanidiot25
Eat My Rust
Re: headers..
Where are you leaking? I've found (atleast with my pipes) that how you rotate the exhaust pipes when bolting to the collector changes the sealing entirely. Today I took the pipes off at school and then threw them back on at the end of class. Leaked the whole way home. Spent 10 minutes loosening the colector bolts and rotating the exhaust pipe around and leaks be gone. Don't have much or a problem at the heads. Would probably double up on gaskets at both ends next time I have them off though.
Ram-horn headers though: http://www.speedwaymotors.com/UNPOLI...OLDS,5425.html
Old 02-11-2009, 01:52 AM   #9
Gray Ghost
Gray Ghost's Avatar
Re: headers..
Got a very slight problem at the heads...from what I can tell it is a head problem versus a header problem, but I am sick of it.
I plan to swap over to a 5.3 soon so the new gaskets I just put on might be the last ones.
Kelly
Old 02-11-2009, 09:07 AM   #10
68Stepbed
68Stepbed's Avatar
Re: headers..
I agree with Sinister on this one. You have other issues to deal with first. Don't take too much advice from an chain parts store clerk seriously. Most of them are only reading the ads and poster flyers they get from HQ.
Headers won't do much good if you still have everything else stock. If you can't get more air and fuel in, you can't get more out. The stock ram horn manifolds flow pretty good and are highly underestimated. Most truck and passenger manifolds had a 2" or 2 1/4" exhaust outlet. The manifolds on Vettes had 2 1/2" outlets, which are better but not necessary. A good exhaust system with the stock manifolds will still work plenty well enough for your engine.
If you do decide to get headers, I recommend getting well known brands like Hedman, Hooker, Sanderson, etc. You can get the plain black painted ones for under $200. When you start getting into ceramic coatings and stainless headers, the prices go up. I've never owned a set of Hooker headers, but I've had two sets of Hedman that never gave me problems. I had a set of the cheap Advance Auto headers on my truck before. They were decent headers AFTER I put the good copper gaskets on them. The paper gaskets they come with are better to be misplaced in the garbage can.
My suggestion is to wait until you build a better performing engine with better components and get a good set of headers instead of buying cheap ones to get you by for now when you don't need them.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-11-2009, 10:53 AM   #11
oldblue1968chevy
Re: headers..
okie dokie
dad seemed to think he knew wat he was talking about (dad dont know much either though lol)
so hooker headers painted black under 200..might look into that later this year sometime...least of my problesm now
John
Old 02-11-2009, 11:00 AM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: headers..
Summit racing has some truck headers that are very reasonable. Another member said he had bought them and the part number was the same as Flowtechs' part number. They will be on my short list whenever I get to that point. Meanwhile, I have a set of Hookers that were on my truck 9 years ago and never leaked at any point in time.....from the flanges or the collectors.
Member Nr. 2770
Old 02-11-2009, 11:18 AM   #13
mrh33916
Project '67 454
mrh33916's Avatar
Re: headers..
Jeg's brand header's are also Flowtech's, I originally purchased painted big block headers from Jeg's, than later bought Flowtech ceramic coated headers from Advance. They are the same right down to the gasket a bolt set.
mrh33916 is offline   Reply With Quote
Old 02-11-2009, 01:54 PM   #14
slednD1
slednD1's Avatar
Re: headers..
thick copper gaskets at both ends w/frequent tightening works great.i use locking header bolts,they are annoying to install but worth the time when done properly.i installed the bolts w/out the locks,ran it a few times and re-tightened a few times before installing the locks and havent had a leak in seven or eight yrs.the gaskets can be re-used by simply heating entire gasket red hot and then quenching in cold water.SCE pro copper gaskets cost about $35.00-do it right/do it once
slednD1 is offline   Reply With Quote
Old 02-12-2009, 08:34 AM   #15
djracer
djracer's Avatar
Re: headers..
buy hedmans they fit and are reasonable! I have hookers on my truck now but I am not a fan of them.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
