Old 12-11-2002, 07:33 PM   #1
4x4 Pray
14-bolt installation question
I just picked up a free 14-bolt with a locker out of a '78 1 ton chevy. I have a 3/4 ton '70 4x4 with an eaton in it right now. Does anyone know anything about doing this swap? Anyone relocated spring perches before? Sounds like a major pain to me. Also, will the overall width of the axles be the same?
Any advice is welcome. I was excited, but now I'm nervous that I got more work than I bargained for.
Jeff
4x4 Pray is offline   Reply With Quote
Old 12-11-2002, 07:40 PM   #2
ozarkhippie
measure the distance from center to center of the spring perches of each axle. If the 14 bolt came out of a 1 ton it should be the same as the one in your 70, so there should not be any spring perch relocation.
ozarkhippie is offline   Reply With Quote
Old 12-11-2002, 07:41 PM   #3
Alexis
Member since 2000
Alexis's Avatar
.............hehe your in for some fun. i just finished doin this swap in my 3/4 ton.Things your going to need are the brake brass fitting 3/16 female to 1/4 male(real pain to find so i incountered). Oh and the U-joint strap kit i used was "360-10" napa.
Alexis is offline   Reply With Quote
Old 12-11-2002, 07:59 PM   #4
Alexis
Member since 2000
Alexis's Avatar
hers a picture
14-bolt FF 4.56 posi
Old 12-11-2002, 08:00 PM   #5
Alexis
Member since 2000
Alexis's Avatar
picture of the fittings
kinda blurry cause i used the program to zoom
Old 12-11-2002, 09:00 PM   #6
4x4 Pray
thanks for the tips. went and measured my perches and the new perches. mine are about 2.5" narrower. guess the 14 bolt is from a 3/4 ton then.
thanks for the pics too. you looking good. mines covered in rust.
Old 12-11-2002, 09:35 PM   #7
jerry moss
Born Psycho
jerry moss's Avatar
i've done this swap on a few trucks, it takes some time but is well worth the effort. you can buy new spring pads at most speed shops, i use a 4inch grinder to cut off the old pads. grind off and re-use the shock mounts (they're staggered on the 79). you'll need an angle guage to set pinion angle, brake line fittings and longer e-brake cables. i get my e-brake cables redone at nevada speedometer in reno nevada. if you have any questions, feel free to call me, 925-634-2512.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 12-11-2002, 10:45 PM   #8
4x4 Pray
925? WOW, you live right by me! I go to school in San Luis Obispo, but my hometown is in Clayton (right by Concord). That's pretty cool.
Anyway, I appreciate the encouragement. You have inspired me to keep on going on this project. But what's an angle guage look like? And can I set the angle some other way rather than buying the guage? Will it screw things up if just I try to get it as close as I can?
Old 12-11-2002, 11:20 PM   #9
roger0080
I've done this to my 71 K20 also.
I'ld rather have the Eaton myself and just pay for the NoSpin diff if you want a locker that bad. You can get a disk brake conversion kit for the Eaton rear end too! Check out: http://members.aol.com/blackbirdstrucks/index4.html
But what I did as others said is you will have to move the spring perches in. I had a shop do mine.
Relocate the shock brackets on the axle, my pinion strap to the yoke and U-joint fit right into the 14-bolt, did a brake job on the 14-bolt since you have it out. The Eaton uses 5/16" brake line to the wheel cylinders where the 14-bolt will use 3/16". No problem. I bought new wheel cylinders for the Eaton and bolted them into the 14-bolt. Ran new 5/16" line from the wheel cylinders to the "T" connection. No fuss no mess.
Hardest part is getting the right pinion angle when it's all done. I had to use some tapered shims and it was pretty close.
-Roger
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
