02-11-2009, 10:24 AM | #1 |
Ready to go fast!!
What kinda numbers???
all my motor specs are in my sig. what kinda 1/4 numbers you think it will be puttin down with good suspension?
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
02-11-2009, 12:36 PM | #2 |
Registered Truck Offender
Re: What kinda numbers???
yeeeesh, we just went through this in another thread. Your gonna have to get a whole bunch more specific if you want anything +/- 5 seconds
weight? short bed / long bed? chassis mods? slicks? gears? Trans? convertor? more specific info on heads (casting # or flow #'s)? conpression? exhaust? ... that would be a good start
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
02-11-2009, 02:49 PM | #3 |
Ready to go fast!!
oh sorry must of not seen it sorry! i will try to get all that i can!
02-11-2009, 03:04 PM | #4 |
Ready to go fast!!
4,000..just a guess
short bed trailing arms, coil overs 29.50 x 12.00 slicks 3.73 gears built 350 turbo 3500 stall 3964292 not sure on the flow #'s but i will get them 10:1 compression hooker comps. 1-5/8" x 27" Primary Tubes into 3 in. exhaust into Dynomax Ultra-Flo Welded Mufflers if this is enough to get some what close take a shot but if more is needed i will do my best lol i just need a little somthing to get me going to get that muther done! lol
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded Last edited by drag_72; 02-11-2009 at 03:06 PM. |
02-15-2009, 06:32 PM | #5 |
Ready to go fast!!
anyone?
02-15-2009, 07:08 PM | #6 |
I'll quess. High 11 to low 12's
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
02-15-2009, 09:32 PM | #7 |
The Engine Whisperer
I'm gonna guess pretty high 12s
02-15-2009, 10:50 PM | #8 |
Dr. Frankenstein
you could run a 14.xx If you forgot that a warm up burnout is supposed to "heat" the tires not shred them to the cores and then slip an slide the whole track
I Wanna Go Fast!! |
02-15-2009, 10:54 PM | #9 |
I would guess somewhere in the low 8s in the 1/8 and low-to-mid 12s in the 1/4. These guesses are motor-only passes.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
02-15-2009, 11:43 PM | #10 |
I have no experience with BBC trucks, but I'd have to say mid-high12's if all goes well and you shift at the sweet spot to torque your way to the stripe. But... just a guess from what I've seen other well built, heavy 454 trucks do at the track. Optimized tune and driving,,, maybe even slip into the 11's in good air. Keep in mind every 2000 feet above sea level will cost you roughly .2 seconds in 1/4 mile ET. Good air / bad air at your elevation will help or hurt your ET too.
02-16-2009, 01:16 AM | #11 |
mini truck racer
spraying outta the hole 11.88.
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
02-16-2009, 01:53 AM | #12 |
Has anything been removed to reduce weight?
02-16-2009, 09:04 AM | #13 |
not much he said 4000 pounds!
02-16-2009, 06:44 PM | #14 |
Hard to say. I've seen a stock headed big cam 454 with headers and intake run a low 14's on the motor and with 180hp jets go mid 12's as I drove around him about the 330' mark. He did light me though...
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 02-16-2009 at 06:45 PM. |
02-16-2009, 09:12 PM | #15 |
what heads are on your motor and how much compression?
02-16-2009, 09:38 PM | #16 |
Ready to go fast!!
i would be happy with high 11's low 12's! thats actually what i was shooting for! but i just got stock heads but they have been worked over. its got 2.19 1.88 vavles and some porting, i got 10.5:1 compression and not a whole lot of weight reduction yet! i have little stuff like no inner finders, fuel cell to back, battery to back, but i would like to do like a glass hood or somthing in the long run but try to keep it all steel? i guess thats just my style lol thanks for all the replies!
02-16-2009, 09:51 PM | #17 |
come up with a casting number on the heads that could make a huge difference
02-16-2009, 09:54 PM | #18 |
Ready to go fast!!
okay are they on the back of the head?
02-17-2009, 08:26 AM | #19 |
they should be under the valve cover
Do you know what the 454 came out of?
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! Last edited by djracer; 02-17-2009 at 08:27 AM. |
02-17-2009, 03:45 PM | #20 |
Ready to go fast!!
oh yah i know where they are now! not really sure what it came out of? we have alot of big blocks around.
02-17-2009, 04:26 PM | #21 |
Dr. Frankenstein
my stock ones SUCK(2.06 intake like 1.8x or something exhaust)they would flow good if they were for a small block
I Wanna Go Fast!! |
02-17-2009, 04:28 PM | #22 |
Ready to go fast!!
i got 2.19 intake 1.88 exhaust though lol and they are ported
02-17-2009, 05:08 PM | #23 |
I'll guess low 13's to high 12's on motor. Let us know when you get it out and make some runs.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
02-17-2009, 05:42 PM | #24 |
Dr. Frankenstein
see so it has to be atleast faster then mine! but i only weigh in at 3400ish now
I Wanna Go Fast!! |
02-17-2009, 08:15 PM | #25 |
Ready to go fast!!
hell yah i will for sure let you know! track has already opened up so i should have a turn key truck in the next few weeks? and ya i wish i could lose some weight lol is that weight with you in it?
