Old 02-11-2009, 11:54 AM   #1
jdmathes074
what rearend do i have?
i need to know what gears are in my rearend. the truck is a 86' gmc 2wd longbed if you need any more info let me know.
jdmathes074 is offline   Reply With Quote
Old 02-11-2009, 12:13 PM   #2
James McClure
One shot, one kill.
Re: what rearend do i have?
jd. Only 2 ways to tell. one is try to get the numbers off the top of the right hand axel tube and take them to or call a dealer parts dept. Second, pull the cover off the rear end, rotate the ring gear and look for a series of numbers. There will be a series of 4 numbers seperated by a ":". Example 15:42 ect. OK, now divide the 42 by 15 and thats your ratio. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 02-12-2009, 01:18 AM   #3
79blazer
79blazer's Avatar
Mine has a RPO sticker in the glove box. It says the ratio with all of the other options.
79 Blazer Cheyenne, 2wd 305 3.42 stock
85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks,
79blazer is offline   Reply With Quote
Old 02-12-2009, 02:04 AM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
On the RPO Sticker in the glove box you need to find the codes that begin with the letter "G".
GU4 3:08 Ratio
GU6 3:42 Ratio
GT4 3:73 Ratio
If you have the "G80" code as well then you have positraction on the truck.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-12-2009, 04:14 AM   #5
fast75
Go Hard or Go Home!
fast75's Avatar
count the teeth on the ring gear and divide that by the number of teeth on the pinion gear. thats a sure fire way of KNOWING what gear ratio you have.............
75 short wide 350, some mods, scare the piss outta ya quick.
2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick.
Some day's, it's just not worth chewing through the restraints................................
fast75 is offline   Reply With Quote
