Old 02-11-2009, 01:04 PM   #1
SBTork
Garage wrench
SBTork's Avatar
Another tire size help question
Im doing a 4.5/6 or 5/7 drop on my 82 C-10 and im wondering about tire size on a 15x8 rally. I like the way the 255/60 15's look, but I think they may be a bit small as far as sidewall. I know they're 27" in diameter, section width is 10" and section height is 6". I was also thinking about 265/70 15, but I think they may be a little big. They run 29.6" in diameter, section width is 10.4" and section height is 7.3". I like a little bit bigger tire, but I think it's too much with that drop, it'll just look odd.
So now im here, wondering what other options are, or if I should just go with 255/60 15's and just shut up. Any suggestions?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-11-2009, 02:16 PM   #2
maxreps
Re: Another tire size help question
What about 255/70? It should be about 29" tall but same width, whereas the 265/70 would be about 29.5" tall and about .5" wider
maxreps is offline   Reply With Quote
Old 02-11-2009, 03:21 PM   #3
Synyster
i know its not a c10 but this might help ya some? im running a 275/60-15 on a 15"x10" rally wheel on the back of my suburban with a 7" drop. i know you plan on running an 8" wide wheel but its another option that might help ya out some. the front is a 205/75-15 on an 8" wheel and 5" drop
"I't not how fast you are, but how low you are when you get there!"
Synyster is offline   Reply With Quote
Old 02-11-2009, 11:45 PM   #4
SBTork
Garage wrench
SBTork's Avatar
that's not a bad idea. I should be fine on the front with stock inner fenders, I mean these trucks can take a big wheel and tire before they need to be cut . I don't think they'd rub, but has anyone tried this?
Also, the 275/60-15's are not bad on a 10" wide wheel, and I know wheel vintiques makes a 10" wide pickup rally. Maybe that's something ill look into for the rear.
-Adam
Old 02-12-2009, 12:07 AM   #5
f.monroe
f.monroe's Avatar
I dont kno if it helps but here is a 255/60 front and 275/60 rear on my old tan truck .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 02-12-2009, 02:13 AM   #6
SBTork
Garage wrench
SBTork's Avatar
Thanks a lot for the pic Frank. That was your old tan truck with a 2/4 drop, right?
-Adam
Old 02-12-2009, 02:29 AM   #7
jared78
jared78's Avatar
With the drop you're doing I've used 245/60/15s on front and 275/60/15s on the back and it looked good. That 275 will mount up fine on th 8s
jared78 is offline   Reply With Quote
