Old 02-11-2009, 05:58 PM   #1
Redden05
Redden05's Avatar
Parts from a parted 70 C20
This is all the parts left from my 70 c20. I will consider offers on all parts. And here we go:
EDIT: This is a list of everything in this topic for those who dont want to go through the posts. If you see something you want, scroll down and find it in the pictures.
Blue Sunvisors: $18 plus shipping
Rear Wiring harness and bezels: $10 plus shipping
6 cylinder Radiator with top hold downs: $50 plus shipping
Hood Latch: $15 plus shipping
Front Bumper: SOLD
License Plate Bracket: $10 plus shipping
Tailgate Hinges: $10 plus shipping
Spare Tire Bracket: $20 plus shipping
Rear Wheel Splash Shields: $15 plus shipping
Windshield Wiper Motor and arms: $50 plus shipping
Truck Camper Brackets: SOLD
Auto Steering Column: SOLD
Auto Pedal Setup: $30 plus shipping
Drive Shaft: $30 plus shipping
Under Dash Wiring Harness: $30 plus shipping
Blue Seat Belts: $20 plus shipping
Interior heater box: $25 plus shipping
1969 350 Intake: $50 no shipping
1972 Valve Covers: $25 plus shipping
Exhaust Manifolds with downpipes: $35 plus shipping
Mirrors: $15 plus shipping
Hood Hinges: SOLD
Gas Tank with 2 gal. of 93 octane gas in it: $20 no shipping
Automatic column linkage (not complete): SOLD
Battery Tray: $15 plus shipping.
Blue Sunvisors in Good Shape. There is only one little tear in it, and they could use a really good cleaning. $20 plus shipping.
Rear Wiring Harness for a 67 or 68 bed. It doesnt have marker lights. Some of the wires were cut and temp. fixed. The metal parts of the tail lights are rusted and through in one spot. $10 plus shipping.
Redden05 is offline   Reply With Quote
Old 02-11-2009, 06:04 PM   #2
Redden05
Redden05's Avatar
Re: Parts from a parted 70 C20
6 cylinder Radiator. In very good shape. The black marks at the left bottom are oil stains. $50 plus shipping.
Hood Latch in Good Shape. $15 plus shipping.
Front Bumper (without the brackets) It has a spot where the metal is bent up. See the pictures. $40 and no shipping.
Old 02-11-2009, 06:16 PM   #3
Redden05
Redden05's Avatar
Home Made License Plate bracket without a bumper or roll pan. With alittle work, this could look really nice. The light is brand new and plugs right into the factory harness. $10 plus shipping.
Tailgate stuff. Needs cleaned up and painted. $10 plus shipping.
Spare Tire Bracket and one of the rods. It is in good shape. $20 plus shipping.
The shields behind the back wheels. The one is broken, but I have the piece and it could be fixed. $15 plus shipping.
Old 02-11-2009, 06:17 PM   #4
chuckmc8
It's alsways something.....
chuckmc8's Avatar
is the tear in the visor on the top side with it in the up position?
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 02-11-2009, 06:30 PM   #5
Redden05
Redden05's Avatar
Windshield wiper motor, rods and wiper arms with brand new blades on them. The motor worked nice. I'm not sure, but I think the washers even worked. But I'm not too sure about that. $50 plus shipping. I will break these up if need be.
Truck Camper Brackets. They were chrome at one time. $10 plus shipping.
Automatic Steering column. It has a 3 speed lens and the chrome on the shifter and turn signal lever has some surface rust. $35 plus shipping.
Automatic Pedal Setup in Really good shape. $30 plus shipping.
A 2 piece Driveshaft that has been shortened for a 700R4 or a long tailshaft 350 turbo. I dont know much about this as it was shortened before I got it. I do not know if it is balanced or not. It has a new rear universal joint in it. $30 plus shipping.
Old 02-11-2009, 06:35 PM   #6
Redden05
Redden05's Avatar
No, it is on the passenger side on the bottom with it in the up position.
Old 02-11-2009, 06:36 PM   #7
Redden05
Redden05's Avatar
1970 Under the dash wiring harness. The truck had full gauges (no tach). The ignition plug has melted on this. It also comes with the harness from the front to the rear which had the insulation stripped off the wires to tap into them for some reason. $30 plus shipping.
A set of seat belts in blue. There is a picture below of all the pieces. Only includes drivers and passenger seat belts, no middle seat belts. $20 plus shipping.
Interior heater box stuff. $25 plus shipping.
1969 Intake off of an 300 hp 350. $50 and no shipping because this is heavy (unless you want to pay for the shipping). Valve covers off of a 72 V8. $25 plus shipping.
Old 02-11-2009, 09:04 PM   #8
Redden05
Redden05's Avatar
Exhaust Manifolds with new studs in them and down tubes. The passenger side manifold is cracked in the back like alot of them. $35 plus shipping.
Mirrors. The top parts are nice (except the bolts are rusty on the back). The parts that attach to the door are rusted out. $15 plus shipping.
Hood hinges. They are tight and could be cleaned up and painted. SOLD
Old 02-12-2009, 12:03 AM   #9
Hart_Rod
Hart_Rod's Avatar
What is the length of the driveshafts?
Hart_Rod is offline   Reply With Quote
Old 02-12-2009, 09:18 PM   #10
Redden05
Redden05's Avatar
The front drive shaft measured from the front u-joint to the carrier bearing, it is 30 3/8 inch. The rear drive shaft measured u-joint to u-joint is 26 1/4 inch. If you want different measurements, let me know what you want.
Old 02-12-2009, 09:47 PM   #11
Hart_Rod
Hart_Rod's Avatar
You wouldn't happen to have any pictures of this installed would you? I'm trying to figure out if this will work in my suburban.
Old 02-12-2009, 09:58 PM   #12
Redden05
Redden05's Avatar
I just might. I will have to rummage through all of my pictures I have. There are no guarantees though. Also, do you want me to get any other measurements?
Old 02-12-2009, 10:42 PM   #13
deweychop
can u give me a price for the hinges shipped to 34116
Are you taking paypal?
Horsepower sells cars
Torque wins races
deweychop is offline   Reply With Quote
Old 02-13-2009, 08:09 PM   #14
Redden05
Redden05's Avatar
Hart_Rod: I found a few pictures of the same kind of drive shaft on a different truck. Do you know if the suburbans and lwb trucks are the same wheelbase? Do you have a 12 bolt in your truck? Mine had a Dana 60 rearend in it and was physically bigger than a 12 bolt, therefore the driveshaft is shorter. Here are the pics:
And here is the driveshaft when it was in the truck (sorry, it was the best picture I could find)
Old 02-13-2009, 08:10 PM   #15
Redden05
Redden05's Avatar
PM sent.
Old 02-13-2009, 08:14 PM   #16
Hart_Rod
Hart_Rod's Avatar
The rearend definitely makes a difference. I appreciate you taking the time to look.
R/
Old 02-14-2009, 05:53 PM   #17
Redden05
Redden05's Avatar
It was no problem Rob.
Old 02-15-2009, 10:20 PM   #18
Redden05
Redden05's Avatar
ttt: all offers are considered if the prices are out of line.
Old 02-16-2009, 08:39 PM   #19
Redden05
Redden05's Avatar
Here is a picture of the seat belts. I thought there was the center seat belts, but I guess there isnt. It has been awhile since I saw them.
I also have a gas tank that is really nice on the inside. It has a small amount of surface rust on the top of it (on the outside) but is nothing to worry about. It is out of a 68 C10. $20 and no shipping.
Old 02-18-2009, 08:11 PM   #20
Redden05
Redden05's Avatar
ttt
Old 02-22-2009, 04:58 PM   #21
Redden05
Redden05's Avatar
bump
Old 02-22-2009, 07:47 PM   #22
crapy67
White wall terror
crapy67's Avatar
You wouldn't still have the wiper switch from the dash would ya? And how far are you from Levittown Pa.
crapy67 is offline   Reply With Quote
Old 02-23-2009, 07:10 PM   #23
Redden05
Redden05's Avatar
Yes I do still have it, but I included it with the wiring harness. I looked on google maps and you are about 184 miles from me.
Old 02-23-2009, 10:10 PM   #24
crapy67
White wall terror
crapy67's Avatar
would you be willing to sell just the switch? if so how much shipped to Pa. zip code 19030? Thanks Mark
Old 02-23-2009, 10:42 PM   #25
timzrides
timzrides's Avatar
If you change your mind on shipping the bumper, i could really use it. I'm located by Springfield, IL..thanks
timzrides is offline   Reply With Quote
