How low SHOULD I go?
I just tubbed my '70 and I'm going back and forth about dropmember/bagging it. I want to keep things as simple and reliable as possible. I've had friends that have been stranded due to blown bags and I dont want to be that guy so I'm really leaning towards static. I have 3" coils and 2.5" spindles installed and its still not quite as low as I want. Running a 26"ish tire I would be comfortable with the stock crossmember being about 3" off the ground with a firm ride. I've dealt with less, trust me. I'm not too keen on aftermarket lowering components. With lowered coils and spindles can I go even lower with dropped arms added to the mix? I know I SHOULD run tubular upper arms but at what point do I NEED them?
1970 Short/Fleet C-10 (Project) -Slammed and Tubbed 1955 Cameo -Straight six, Turbo Hydro option 1955 BelAir 2 door post -All original down to the oil bath air cleaner 1964 Corvette -All power A/C 327 4 spd. tanker ![]() |
dazed and confused
Re: How low SHOULD I go?
there is aguy on the board who lowered his truck static quite a bit maybe he will chime in tcb-1 i think
members met: redbaron69, billsbowtie,nc67 |
what is the best way to lower a 1969 stepside 2wd that will have the tank in the rear? i want a nice even stance. what should i go with what kit would i use and things like that?
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 ![]() ![]() |
#4 | |
resident oilfield trash
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
![]() Join Date: Nov 2008
I would personally go this low.....wont feel no regrets afterwards!
3 inches!
![]() what? do they not have bumps in the road in texas? ![]() seriously, i know nothing about lowering, but it looks damn cool, and im trying to learn about it. good luck, hope you get what you want with your truck..
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
You should leave your truck with me for a few hours. It would be slammed in no time. Funny you should say that I once tore off an arm on a man hole cover that was built up about 6 inches. I was going about 60. Fun ride just had to change my pants afterwords. If anyone from Lubbock reads this be ware it is at 34th and Q.
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() Last edited by jbristo67; 02-12-2009 at 12:40 AM. |
Hey man PM Bob 68327 he may be able to give you the insight on static drop...he's not much for out-of-the-box either. He's a pretty cool guy and hell, he's my neighbor.
I should have some pics by Sunday. My truck is mocked up for now. Bare bones cab, complete doors, dummy engine and tranny, core and fenders nothing else. Im expecting a couple hundred more pounds with all the little stuff but the way it is now my 27" tires are about an inch away from the lip of the fender. It needs to tuck a couple of inches before it will look right.
Maybe a big block will give you another inch of drop not sure
70 SWB STEPSIDE 70 BLAZER 09 challenger |
what size wheels and tires are you running
15"s
#13 |
drop until you see sparks ... then go back up about an inch
#14 |
Nothing to see here.....
![]() Join Date: Jun 2007
right on!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
#15 |
I'm a firm believer of "all the way."
If your air suspension system is installed correctly, and you use quality parts, it will never leave you stranded. Of all the times I have been stranded, it's always been a dead battery, the carb, or something else with the engine. Never once have I had a suspension issue in the last 3 years of daily driving.
If you can find it cheaper, I can fix it! |
#16 | |
#17 |
Honestly I don't know. I am not really a big fan of Shockwaves, so I don't know much about them.
However, I have always wanted to build a cantilever setup that uses a small stiff air cylinder for lift, and a nice coilover in place of the lift bar. That way you would always be riding on the coilover at any height you want. With a small diameter air cylinder, they don't compress much at all, much like a small hydraulic cylinder. So the majority of the suspension movement would be absorbed on the coilover end.
#18 |
Thats a great idea but a little too complex for what I'm shooting for. I'm still not eliminating the bags.
#19 |
odes 72
basic and simple bag job small c-notch and drop spindles
odes 72 ![]() |
