02-11-2009, 07:45 PM | #1 |
Measurement please.
As always I'm getting ahead of myself. I am thinking about a new project and have an idea. But I need a few measurements.
Can I get the width from inside right rocker box to inside left rocker box. Width from body lip to lip in the same area (under the doors). Thanks ahead of time! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
02-12-2009, 01:12 AM | #2 |
Wide n'Low
Re: Measurement please.
I can take some measurements tomorrow when I get up to the shop. Will post them when I get home.
Drew
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
02-12-2009, 03:43 PM | #3 |
The LuvShack Garage
If mine wasn't sitting on the ground I could measure mine, sorry
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-17-2009, 07:39 PM | #4 |
Thanks guys. Sorry, I didn't get the info that anyone had responded. I am thinking of an idea, but it involves a frame replacement and I know the width of the old fram, but not the width between the rocker boxes, etc. Thanks again!
Shawn
02-17-2009, 09:00 PM | #5 |
Wide n'Low
My apologies, I was there working and totally forgot! I might be at it again this Friday. I won't forget this time around.
02-18-2009, 07:44 AM | #6 |
Wouldn't you need/want the inside measurement between the torsion boxes?
That dimension would be even less than the inner rocker #'s would be. The frame drops inside the inner torsion boxes, not the inside if the inner rockers. Maybe I'm confused here sorry... |
02-18-2009, 08:25 AM | #7 |
Aren't the rocker boxes and torsion boxes the same thing?
02-18-2009, 09:41 AM | #8 |
That is what I meant. I thought they were the same thing too.If they are not then I apologize. I need the measurements between the torsion boxes then.
Thanks! Shawn
02-18-2009, 10:01 AM | #9 |
Nope!
Outer rocker is what you see beneath the doors, inner rocker is a flat piece directly below where the weather-stripping goes (what the outer attaches too), torsion box is behind those pieces & contains the torsion rod. 1st pic is the drivers side torsion box, notice the 'box'. 2nd pic is the inner rocker. 3rd pic is the outer rocker. Hope this helps... |
02-18-2009, 10:06 AM | #10 |
Sorry J, got side tracked.
Inner most measurement taken from just behind #1 body mount is 39 inches. Inner most points taken just forward of #2 body mount is 46 inches. When I refer to "inner most point" I'm not taking the measurements directly from torsion box to torsion box, there's a drop from below the tub prior to the boxes that would affect lying on a different frame, those are the points I took the #'s from. Last edited by vtblazer; 02-18-2009 at 10:08 AM. |
02-18-2009, 10:12 AM | #11 |
Ahh it makes sense now. I just ASSumed that the inner rocker was part of the torsion box and that the outer rocker attached to the torsion box. You the man. NOw get me the measurements I need!!!
02-18-2009, 10:13 AM | #12 |
Dang! I type too slow!! Thanks for the measurements! I will have to see what I can come up with now.
SHawn
02-18-2009, 10:15 AM | #13 |
02-18-2009, 10:20 AM | #14 |
No, I was typing too slow and you posted before I responded to your post before. Can you tell me a little about the "drop from below the tub prior to the boxes that would affect lying on a different frame" Is that the piece that runs parallel to the torsion box in the pic above (the one that looks like it has a series of holes in a line)?
02-18-2009, 10:45 AM | #15 | |
Okay, pics tell the story better... Fresh out of the garage. |
02-18-2009, 11:10 AM | #16 |
Okay! Awesome I see now! Okay, so in your opinion,
A: Can these areas be modifies to gain the distance from torsion box to torsion box? B: If not, if the body sat higher to avoid hitting these braces, how much lower would the frame need to be to clear them? It looks minimal, like 1/2" or so. Is that correct? Thanks again for all of your help! Shawn
02-18-2009, 04:24 PM | #17 |
So how wide is the blazer frame from outside to outside frame rail in between the torsion boxes?
02-18-2009, 05:09 PM | #18 | ||
B: The first drop steps 2-3/4"s from the bottom of the floor & to the bottom of the torsion box, it's 6-1/4"s from the tub floor. Quote:
Front is 33-1/4"s Rear is 34"s Torsion boxes inside/inside. From front at the narrowest point before it jogs is 43-1/2"s From the furthest point rearward of the torsion box is 51"s **Please keep in mind that all these old trucks my not measure up exactly the same. |
