02-11-2009, 09:04 PM | #1 |
ho72, drw, 4:10 and hop52 srw both complete
i have 3 complete rear axles for sale.
1st axle- ho72, dual rear wheels, 4.10 gears, open diff. 2nd axleS (2 ) -ho52, single rear wheel, from behind a automatic trans so i assume its a 4.10 also and most likely a open diff 125.00 EACH bob in kingsport, tn. 423 384 8938 BOTH ARE COMPLETE STOCK AXLES STILL UNDER TRUCKS
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 03-11-2009 at 02:27 PM. |
03-11-2009, 02:28 PM | #2 |
Re: ho72, drw, 4:10 and hop52 srw both complete
Ttt
I BELIEVE IN JOHN 3:16 |
03-23-2009, 03:15 AM | #3 |
Bob do you know if there is a difrence between the SW and DW hubs on the eatons I am wondering if I can put the DW hubs on the SW axle to make it wider like on the 14blt axles.
Earl 68 2500 4x4 GMC Burb |
03-23-2009, 12:27 PM | #4 |
Srw hubs will make it the widest however the drw hubs will interchage but you need to change out the brake systems also. Drw brakes are bigger. I have both if you want to just come and look.
Bob
03-23-2009, 12:31 PM | #5 |
Ill try and stop by this week and take a look. I have disk brakes on mine so Im just trying to find a way to make it wider so I can run hummer H1 wheels and tires. I seen on the NC4x4 site you were going to buy the rest of the ones for sale over there did you ever go get them ?
03-23-2009, 07:35 PM | #6 |
Yes i,ve bought all he has had. I have a bunch of new hummer tires & wheels. Call before you come so i dont miss you ok ?
Bob cell 423 384 8938
