Old 02-11-2009, 10:02 PM   #1
slugish
Slugish
Dash pad dillema
Bought a black dash pad from dash direct
* now i want it grey > have had it 6 mo,s or so probably wouldnt exchange it & even if they did freight charges would be too much.
* on label it says " not paintable "
* so i call sem > they said it could be painted ( or dyed ) but all the stuff i would have to buy to prep it & special paint for it would be quite expensive
* has any of you done this & if so did it turn out ok
slugish is offline   Reply With Quote
Old 02-11-2009, 10:43 PM   #2
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: Dash pad dillema
Here's one from the FAQ:
http://67-72chevytrucks.com/vboard/s...d.php?t=169470
No, I haven't done it.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 02-11-2009, 11:17 PM   #3
bigblock73
yeller
bigblock73's Avatar
It won't work, the pad is soo flexible and flimsy it'll crack like an egg.
bigblock73 is offline   Reply With Quote
Old 02-12-2009, 09:00 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by slugish View Post
.....* on label it says " not paint able "
SEM did not make the dash pad. They do make the product they are telling you to buy to paint the dash pad. If it fails SEM will not warranty the product because the manufacturer of the dash pad states " not paintable ".
I'll let you do the math here...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-12-2009, 10:49 AM   #5
mhicks
mhicks's Avatar
The "not paintable" one I bought had an oily film on it. I tried acetone and several other things to get it off so I could paint it. Worked pretty good in most places but still have a few problems with it. Ended up getting another one.
mhicks is offline   Reply With Quote
Old 02-13-2009, 12:13 AM   #6
slugish
Slugish
Thanks for your responses. Ithink Im going to have to be satisfied with the black .
Old 02-13-2009, 12:22 AM   #7
xs-style
xs-style's Avatar
Could always sell the one you have and buy another in your correct color.
xs-style is offline   Reply With Quote
Old 02-13-2009, 02:50 AM   #8
dammitmitchell
the pollock
dammitmitchell's Avatar
the classic industries catalouge has dash and door pain specifically for vinyl...
my buddy "boejaker" did his and it looks great..
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 02-13-2009, 01:10 PM   #9
copperchevy
copperchevy's Avatar
You could get it covered. A good upholstery guy can make it look nice.
Mexican
copperchevy is offline   Reply With Quote
Old 02-13-2009, 10:48 PM   #10
slugish
Slugish
Yea , but what Iunderstand , some are paintable & some or not > the tag on mine says not paitable . got to be differences in what they make these pads out of.
Old 02-14-2009, 08:27 PM   #11
Vixvega
It will look great if you paint it and never ever drive the truck and keep it in a climate controlled 72 degree room. Other than that, experience tells, Save yourself a lot of aggravation.
Vixvega is offline   Reply With Quote
Old 02-15-2009, 12:32 AM   #12
LBJ
May be too late for input. I bought one that said "Cannot Paint" and painted it anyway. the secret seems to be cleaning the tar out of it. I used the SEM cleaner with a scotchbrite pad. Then primed it with the special primer and then painted it with SEM dye. It's been on for 1.5 years so far and good except for some small areas in the creases where I may not have cleaned it good. The bulk of it looks great though. Good luck.
LBJ is offline   Reply With Quote
Old 02-19-2009, 06:29 PM   #13
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Was it the skinned vinyl version or the urethane version that weighs 100lbs?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-19-2009, 11:08 PM   #14
slugish
Slugish
Mine is urethane Chris , but your post may have been directed to LBJ
Old 02-19-2009, 11:56 PM   #15
LBJ
I think they called it urethane. It was fairly heavy. I have the original and it's not the same as the LMC version.
Dash Top made it as I recall. Same as made those crappy door panels that don't fit.
I posted this a good while back. It turned out nice. I like the color better than the original which was brown. I wanted it to match the seats and door panels.
Old 02-20-2009, 01:23 AM   #16
spudz
spudz's Avatar
I have painted them... BUT you a good water based degreaser and scuff up the surface... you cant have it clean enough... then get some good fye... Not the cheap walmart crap... good stuff.. and it will last.. It will eventually wear off where you touch it the most... but that could take a couple years..> Then you can always repaint it... I wouldnt be afraid to dye it...
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
