67-72 parts collector,…
![]() Join Date: Nov 2002
6-lug to 5-lug questions,... (experts/gurus check-in)
OK, experts,...
what do I need and where do I do my shopping. My '69 swb is getting disc brakes and 5-lugs up front. I know I need 5-lug axles out back. What else do I need? Do I just buy 71-72 brake drums? Do I need 71-72 shoes and all the other brake hardware? Are the backing plates the same? And lastly,... who has the best deal on axles? ECE, Moser,... who? Thanks, in advance,...
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-12-2009 at 12:33 AM. |
#2 | |
I have a radical idea!
Re: 6-lug to 5-lug questions,... (experts/gurus check-in)
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-12-2009 at 12:28 AM. |
resident oilfield trash
I bought some McGauphy drop spindles(on late model I always use beltech these were every bit as good). Then I went to a junk yard and got some 5 lug rotors off of a 94 Chevy 1500. I got my rotors for 20 dollars and got them turned for another 20. Rotors through LMC will cost about 120. 73 to 87 will use mostly 1 inch rotors and 88 to 98 will use inch and a quarter. When you order your spindles you will need to tell them if you plan to use 1 inch or 1 1/4 rotors. To be honest with you unless you have alot invested in your rearend I would just find a rear end out of a 71 or 72. You will easily have 400 in converting your rear end and I know where there are about 20 rear ends for about 200 complete. So it just comes down to finding one in your area. LEt me know if you have any more questions
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() Last edited by jbristo67; 02-12-2009 at 12:34 AM. |
#4 | ||||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-12-2009 at 12:41 AM. |
#5 | |
I actually agree with as well unless you have new internals in your rearend or just want the narrow one. . If wasn't machinist by trade, I would have probably just changed out the rearend. I have several 5 lug axles, but I only changed mine over because I specifically wanted the narrow axle.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
If you have a grey hound stop close to you you could get one of these rear ends shipped to you for almost nothing. They have so many you could prob pick you ratio too. He is a board member if you think you might be interested let me know.
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() Last edited by jbristo67; 02-12-2009 at 12:51 AM. |
![]() Join Date: Oct 2002
lolife,you will be better off getting a 71/72 rearend unless you especialy want a narrower rearend for wider tires and deeper inset.67,68,69 and some of the earlier 70s had narrower rearends than 71/72 .some of the 70 models had the wider rearend and the axels will swap.You can also do as suggested and weld up your axels and drill for the 5 lug pattern then you would only have to swap out the brakes.
#8 | ||
He has a rear-end that he already knows about it's service life & it's already installed; it's just a different bolt pattern. Swapping in stronger than OE, brand new (zero wear @ the bearings) axles is a no brainer vs. a rear-end of unknown quality from a wrecking yard.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-12-2009 at 01:08 AM. |
thanks for all the replies.
SCOTI,... thanks for the specifics. I have a 71-72 rearend,... I'm just trying to decide if the narrower 67-70 rearend is worth the extra money. I want to tuck my 15x10 truck ralleys.
I agree with the new bearings idea.
Both of my rearend will require new brake parts.
Heck..... You don't even have to get drums then.
#12 | |
There's still the issue of width though. Lolife says he may want the narrow rearend for same reason I did. However, if you change out the axles in a '69 rearend and just pop a set of 5 lug rallies on them, they sit further up in the wheelwells and don't look as good (IMO). If I wasn;t planning on running bigger, wider rims in the rear, I would want the 71-72 rearend.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-12-2009 at 01:30 AM. |
#13 |
how much narrower is it
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
#14 |
I believe about 3/4" per side. (1.5" total)
#15 |
Thanks again for all the input from everyone. I have a set of 15x10 (5" B.S) truck ralleys with new 275/60-15's that I had on my blazer. I want to use these on the '69. So I think the "narrower" rearend will be the way to go.
I'll have to check the condition of my 71-72 brake drums to see if they are useable. Hopefully new axles, bearings, seals will do it.
#16 |
![]() Join Date: Feb 2000
I have a 69 Short Fleet that has had the axles redrilled for 5 lug. It has worked fine except for one minor detail. I have 8" x 15" Rallys (Don't know the backspacing) on it with 275/60/15 tires. The inside of the rear tires will rub the inner side of the wheel tub when turning into a driveway and the rearend is twisted from climbing the curb.
So in my case I would like to have the wider axles to give me another 3/4" offset. |
#17 | |
I still stand by my recommendation of using what you have if it's a pre-69 truck unless you know the rear-end is junk. Even @ 1yr of service under my ownership, I would still feel better vs one that came from a pile of rears. *I actually thought he aready had a shorter width housing installed & he just wanted to get it to 5-lug.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-12-2009 at 08:32 AM. |
#18 |
SCOTI,... You are correct. The original 6-lug "narrower" rearend is in the truck already. I just want to go to 5-lug. My old '71 swb is getting parted out. I had thought about using that rearend,... but it has a pretty good leak at the pinion seal and I don't know much about it.
#19 |
Tot Roddin'
Great thread lolife99!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#20 |
1970 Daily Driver
Here is a post with some prices and links for you.
http://67-72chevytrucks.com/vboard/s...d.php?t=326098
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
#21 |
Hey guys,
Just would like to chime in here for a second. I just sourced out and am going to pick up this weekend a 67 chevy rear-end. It's 3.63 vs. my 3/4 ton's 4.11...ideal for some quicker speed. Here's the Link The question is: is the 3.63 going to be narrower than my '71's 4.11 just based on what year truck they came on? |
#22 |
Its70,... thanks for the link!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-12-2009 at 12:53 PM. |
#23 |
Restoration Virgin!
Hey lolife,
I think someone did a write up rebuilding the front suspension (including disks etc) with part numbers etc from a local auto part store....cost him like $600 for everything....I'll try and find it for you, unless you would rather go another route?!?!...I'll look for the thread....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 02-12-2009 at 01:22 PM. |
#24 | |
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com Last edited by HuggerCST; 02-12-2009 at 02:08 PM. |
#25 |
Hey lolife, for my .02. I bought a pair of 5 lug axles from ECE and was very impressed with the quality and service. You definately need to measure your old axle for length (and spline count?) as I ended up with the wrong one on the first attempt. Also, somebody mentioned used rotors at $20 and then paying $20 more to resurface. Man, that is too high in my book. You can buy the new 5 lug rotors all day for that or less at any NAPA or O'Reilly's. I think most vendors are around $750 - $800 for a complete front end conversion kit. If I remember right, I think I ended up with about $1100 for the kit plus a couple of rear axles.
