02-12-2009, 01:35 AM | #1 |
Restoring a 68 SWB
Remove Parking Brake Cables??
I am sure this is really simple, but I had a terrible time with this the other night, and need some info. I got a new 5 lug rearend and I was trying to remove the parking brake cables from the 6 lug rearend that's on the truck now. I can't seem to get enough slack to pull them through that hole on the clip (you know where they come together on the trailing arms). Can someone please tell me what to do. I know it's simple.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
02-12-2009, 01:48 AM | #2 |
Future TOTM Winner
Re: Remove Parking Brake Cables??
I recently removed my rear axle from my blazer. I left the cables hooked to the brake drum internals, but I easily disconnected them from the main cable that runs behind my transmission. I think if you disconnected this end first, you would have enough slack to remove them from the brake shoe hardware...just a thought.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 02-12-2009 at 01:49 AM. |
02-12-2009, 05:19 AM | #3 |
Restoring a 68 SWB
Thanks. I'll give that a go.
02-12-2009, 08:30 AM | #4 |
sharp as a marble
look carefully where the cable goes thru the backing plate. There is a cone ( ? ) shaped clip that is about 1/2 inch tall and has 6 ( i think ) legs on it. 3 of them will be spread out larger than the hole. What I did yesterday on a 69 Olds ( same ) is to pull on the cable from the back side of the backing plate, and take a flat blade srcewdriver and find each of the 3 legs and pry on them. when I got one to release, I would tilt the cable to keep it from springing back in place and move on to the next. I PROMISE this will try your patience. I have done this a bunch of times, and still have a bad thought or two before I am done
02-12-2009, 08:51 AM | #5 |
I am a Referee of life.
So what you need is a small piece of tubing.It needs to be about the size of the hole in the backing plate.Or just a tad smaller.Push it up over the cable and the little plastic clips.Then the clips will be depressed.You can then just pull the cable thru.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-12-2009, 10:03 AM | #6 |
Try pushing a 1/2" box end wrench over the retainer clip on the backing plate to compress the three tabs, it works!
Good Luck Bill |
02-12-2009, 10:13 AM | #7 | |
Under Construction
I think Dave is referring to the C-clip style connectors that connect the front and rear cable together. As critter stated, by the transmission there is an adjustment linkage, you cant loosen this or completely remove allowing the cable to have enough slack to be able to get the rear end cable throught the C-clip connector to be able to remove. We did this a couple months back when switching from 6-lug to 5-lug.. good luck....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
02-13-2009, 02:45 AM | #8 | |
Restoring a 68 SWB
02-13-2009, 10:27 AM | #9 |
Under Construction
Dave, let me know if you have ?'s or need pictures. we are still in the frame stage no body on at this time.....
02-13-2009, 10:42 AM | #10 |
Under Construction
ok, things slowed down at work. so i snapped a couple of pictures. The 1st pic is the parking brake adjuster, this can be loosened or removed to allow enough slack to remove the C-clip that connect the two cables.
02-13-2009, 10:56 AM | #11 |
Restoration Virgin!
This diagram may help too???...It's for 67/68 ebrake setup...
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 02-13-2009 at 10:56 AM. |
02-13-2009, 12:07 PM | #12 |
Restoring a 68 SWB
Thanks for the visual guys. I'll have a chance to get back to the garage today/tomorrow. I should have it off in no time. Thanks for the pics and info.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor Last edited by tdave00; 02-13-2009 at 12:08 PM. |
02-13-2009, 12:31 PM | #13 |
Under Construction
My pleasure.....
11-04-2017, 03:40 AM | #14 |
I switch from manuel gear to 350 automatic on my 67 truck. I also removed the old parking cables underneath. My question is: Can I use the same system as it was, or do I need to get another parking brake system underneath?
Get a little confused when I watch LMC instructions for new cables..http://www.lmctruck.com/icatalog/cb/865w/0152.jpg There are several notes on the bottom on the page. |
11-04-2017, 04:43 AM | #15 |
There really is a lot there to decipher. Thats a good diagram, though. I need to look at mine closer and see how to go about repairing mine. It is good all the way to the back, and it looks like I would just need section "5" on mine and whatever hardware is needed. When we did the brakes a couple of years ago, we discovered that the cable was shredded at the brake shoes and no longer connected. I suppose the previous owner never bothered to fix it.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
11-04-2017, 04:52 AM | #16 | |
11-04-2017, 07:03 PM | #17 |
Old thread but I'll chuck a tidbit out for everyone.
Those pesky fingered retainers that hold the cables into the backing plates on the axle or up in the frame just in front of the cable adjuster. I use a small worm gear hose clamp and snug it just enough so it flattens the fingers to the cable just enough to pull it through the plate or frame. The holes are usually big enough that it only takes a little pressure from the hose clamp to get the fingers started through and a slight tug from the other side of the plate or frame that usually slides the hose clamp rite off the fingers as your tugging. Works like a charm everytime.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
11-05-2017, 12:54 AM | #18 |
I've wrestled with exactly what you're talking about - that is a great idea, thanks.
11-05-2017, 12:47 PM | #19 | |
I'm sure a bunch of us have gotten a few gray hairs from these fingers. Just had thought, I wonder how one of those newer fuel line disconnect tools would work on them.
