Old 02-12-2009, 02:00 AM   #1
sswitzke
sswitzke's Avatar
Help Trucks wants to die
Need some help please, truck will run fine idel fine then sometimes when I get off the gas at stop signs or to turn it will die. It will fire right back up and run fine again. Any ideas? Thank you.
sswitzke is offline   Reply With Quote
Old 02-12-2009, 03:40 AM   #2
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: Help Trucks wants to die
What carb are you running?
When was the last time you changed the fuel filter?
It sounds like the fuel filter is clogged or fuel line pinched.
But it could be idle adjustment.
Need more info.
heavychevy79 is offline   Reply With Quote
Old 02-12-2009, 04:17 AM   #3
fast75
Go Hard or Go Home!
fast75's Avatar
you may have water in the gas tank
75 short wide 350, some mods, scare the piss outta ya quick.
2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick.
Some day's, it's just not worth chewing through the restraints................................
fast75 is offline   Reply With Quote
Old 02-12-2009, 04:31 AM   #4
willett
Another Day, Another Dollar
willett's Avatar
change your air filter, change your fuel filter, and blast some carb cleaner down your carb.
if that don't fix it then you probably need to make carb adjustments
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
