Old 02-12-2009, 02:40 PM   #1
71c10bbsuper
71c10bbsuper's Avatar
Unhappy woodgrain for gauge cluster and glove box
what is the most orignal woodgrain out there?
are there many choices or are they all preety much the same?
i am doing a complete restoration and putting the old wood grain back on
will really stand out and look bad
help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
71c10bbsuper is offline   Reply With Quote
Old 02-12-2009, 03:55 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: woodgrain for gauge cluster and glove box
For the guage bezel, I am not sure, but there seems to be a problem with shrinkage over time. I recommend trying to find the newest batch out of somewhere. The trick that I have found out on the board and did for mine is to get some Contact Cement for like Counter tops & such and put that on the back side of the overlay. It helps to reduce the shrinkage on them. Just be sure to clean it before it dries if you get any around the edges. For the glovebox, I recommend getting a whole new aluminum piece with the woodgrain already stamped on. I used a overlay for mine, but will probably get the whole aluminum and everything this time around.
Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-12-2009, 04:45 PM   #3
71c10bbsuper
where did you get your woodgrain and where can you get the aluminum
piece with woodgrain already on it?
Bruce
Old 02-12-2009, 10:54 PM   #4
71blksuper4x4
SWB 4x4 Collector
I got mine from a board member "Teeitup" it was some old stock from a closed up parts place. You can get both of those at any truck parts place. I like Ron Mane's truck parts. (Mane's Truck Parts)
TREVOR
Old 02-12-2009, 10:57 PM   #5
kristoferlarson
kristoferlarson's Avatar
im sure with a little patience and a guy who sells veneers you could have whatever you wanted there are tons of different real wood veneers some even come prefinished with 3M adhesive on the back just spray the other surface with a shot of contact cement. did it all the time when i was resurfacing cabinets!
kristoferlarson is offline   Reply With Quote
Old 02-14-2009, 07:57 AM   #6
I wish you could get the Cheyenne Super/Sierra Grande pieces like factory.Someone should make photo-etched pieces like the factory.
Old 02-14-2009, 11:52 AM   #7
70LonghornCST
Moderator
70LonghornCST's Avatar
I got mine from http://www.classicparts.com/.
Adhesion was still an issue. I used a hot blow dryer to help adhere the woodgrain. It worked wonders. It helped to vulcanize the glue on the back of the decal to the face of the bezel.
I originally got a new plain bezel and tried to adhere a new decal to it myself. Boy, what a pain trying to line it up. I found it worth the extra money getting one already put on for me. Maybe you have more patience than I do. I think I paid $59. I used my stovebolt discount code and got a 10% discount by typing in "stovebolt" in the discount code field at checkout.
Good luck.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
