02-12-2009, 05:20 PM | #1 |
Another drop shackle question
hey everyone i tried to search but couldnt find an answer. I have an 84 swb with 4" dropped leafs in rear. I just got a new set of 2" dropped shackles to get my desired 6" drop in rear. My question is, does the bed have to be absolutely removed in order to trim the bed crossmember? I do not want to do this and i would rather leave the bed on, is this possible? Also will i need lowered shocks as well? Can the leaf springs be removed in order to cut the bed, or? Thanks for looking- Shaun
02-12-2009, 09:15 PM | #2 |
yeller
Re: Another drop shackle question
You can unbolt it and slide it back far enough to cut out the section...I did that on my truck years ago. However, it is easier to take it off...it will allow you to make better cuts and clean them up easier.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
02-12-2009, 11:07 PM | #3 |
tryin to get laid
I did it on a lift with the shackles and the bed still on.... it sucked ass
02-13-2009, 04:11 AM | #4 |
I would say take the bed off and do it right. Right now im in mock up on my truck and im taking my bed on and off. Me and my uncle dont have much of a problem taking it on and off. It helps a lot when its that low. and when we have three people around its real easy. Just try to find a couple guys and you should be good.
02-13-2009, 07:38 AM | #5 |
Go Hard or Go Home!
took the words right out of my mouth, LOL. this is the easiest way.
75 short wide 350, some mods, scare the piss outta ya quick. 2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick. Some day's, it's just not worth chewing through the restraints................................ Last edited by fast75; 02-13-2009 at 07:39 AM. Reason: if there is an easy way............ |
02-13-2009, 11:15 PM | #6 |
Slugish
Iagree > the way mine was done also . no need to remove bed
