Wheel Spacers
![]() I could get a good deal on a set of these wheels, but... The hole in the back of the wheel is too small to fit over the end of the axle on the rear of the truck. I tried one on, and with about a 3/8 inch spacer and longer studs, they would fit fine. So, I guess I have 3 questions. 1. would it be safe to use a spacer like that? 2. Does anyone know where I could get one made that would work? 3. How much would it cost? ( I am converting to 6 lug disc on the front, and I am going to call tomorrow and get the measurments of the rotor to make sure the front ones would fit.)
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 12-12-2002 at 01:57 AM. |
if has the same bolt pattern, you should be able to use longer studs and a spacer plate
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Yes, it's the same bolt pattern. I actually brought one home and tried it with a 1/4 inch spacer, but it wasn't quite enough.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Anyone else have any coments? Is using a 3/8 inch and longer studs ok? Where could I get one/get one made?
Slowly getting CRSS...
i have a 1/4'' and a 5/16'' spacer on the frotn of mine, the stock studs work i just have the longer Cragar style lugnuts
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
Cool, so the spacers like that will work? Where did you get them? I tried the wheel on mine with a spacer that wasn't quite big enough, and I will definintly need longer studs.
actually spacers will work but they are not all that safe. i have seen a lot of wheel studs breaking off because of spacers i would look into a different method of making them fit
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Low & Slow
Hey Neonlarry, Who makes those wheels?
Cantankerous Geezer
Cableguy's right. They are not safe, unless they have a feature to take the shear force into the hub. The lug bolts are designed to only take a tension load, which holds the wheels against the drum. That's why the lug studs break.
What you need are spacers that nest over the hub and step down to nest inside the hub of the wheel. Unless you have the ability to machine them yourself it will probably be cheaper to buy wheels that work.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
![]() Join Date: Sep 2001
Don't forget wheel bearings. The farther the point of force is at right angles from the bearing the harder the bearing has to work. In other words the thicker the spacer the more wear you'll have.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
i know they are not safe but n order to get my rims to fit i had to grind off part of the caliper to make em work w/ the spacers. iposted about this in the reviews regardin the cragar ss classic rims. i cant see any other way to make em fit other than goin to a smaller rotor. and they are custom backspaced in hopes the woulda fit w. out the spacers.
ohh i go the spacers from summit
SLICER AND DICIER
OK guys he's talking about the back axle. I had the same prob heres what I did.
Pop the cap off the wheel set it up on the lugs and look through the center. It only misses fitting by maybe a 1/16". I called the wheel place they said it is made for 73 up axles. So I busted out the angle diegrinder and trimmed her up. Went on perfect. The wheel spacers are FINE!!! If they are machined correctly as mentioned before. Don't use those CHEEZY spacers from autozone. I run a set of spacers on my 95 Tahoe to go from a 5 to a 4. 5 bolt pattern, they are 1.5" thick and been on there over a year now. ![]()
01 Tahoe 22's 2/4 drop and tv's ![]() 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
#13 |
Spacers & adapters
Cheap (cast alum) spacers should be kept to minimum thickness as possible & shouldn't be stacked. An adapter is different (my guess is this is what NSANE is using) as they physically bolt to the hub w/the stock studs & then you bolt the wheels to the studs machined as part of the adapter. You can get these off the internet from 7/8" up to 4" for approx 100$+, made from billet & you can even change the bolt pattern within limitations. Do an internet search for wheel adapters. I'm using some on my 74 w/5 on 5" bolt pattern to mount my 5 on 4.75 - 20x10's Torq-thrusts.
