02-12-2009, 11:42 PM | #1 |
67-72
Help with rear suspension!!!
i need help deciding what to do for a rear end locator. i will be narrowing the rear end so there lack of room. so i need to keep it between the frame rails. let me know what you all think. thanks alot.
02-13-2009, 12:14 AM | #2 |
Re: Help with rear suspension!!!
Can it be as wide as the outside of the frame?
I would build a panhard bar as long as you can. Otherwise I would try a watt's link with one link mounting above the frame rail and one mounted below it.
If you can find it cheaper, I can fix it! |
02-13-2009, 12:33 AM | #3 |
67-72
i was wondering if it would work if i tied the two lower bars together with a bar diagonaly from the front of one to the rear of the other..... like so. that should keep the rear end from moving. otherwise do they offer a watts link with the diff cover bracket for a gm 12bolt? or do i weld a bracket to the cast diff? thanks again
02-13-2009, 02:52 AM | #4 |
You can run a bar like that, and they work pretty well. Just make sure your frame and axle mounts are solid, as it increases the stress they see.
For the watt's I generally make a bracket that welds to the axle tubes instead. I don't trust the other methods as much. I don't like welding to cast if I can avoid it. Especially cast iron.
02-13-2009, 06:07 AM | #5 |
>130dB Moderator
What about a wishbone?
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
