Old 02-13-2009, 12:36 AM   #1
curly68
curly68's Avatar
sending unit float
I have a friend that has 67 stepside. He has replaced the float on the sending unit about 4 times. The floats keep getting cracks in them. Has anyone else had this problem? He said has checked for burrs on the arm. Thanks for the help. Mike
curly68 is offline   Reply With Quote
Old 02-13-2009, 12:41 AM   #2
Mister laugh
Re: sending unit float
Is he using quality one or cheap repops? I got one from a GM dealer last April I don't know if they were NOS or they are still an active part though. If you can get them i would suggest that as long as the arm has no burrs.
Mister laugh is offline   Reply With Quote
Old 02-13-2009, 12:47 AM   #3
cdowns
cdowns's Avatar
dip them in gas tank sealer
Old 02-13-2009, 12:53 AM   #4
jorgensensc
jorgensensc's Avatar
I'm still trying to find the right solution. I think that jeeps had plastic ones that would fit on the arms we have. I saw them on a jeep websight at some point. But I'm not sure.
Shawn
here is a pick of one off a cj from like 55-86 I think.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-13-2009, 01:02 AM   #5
jorgensensc
NOw I found this: http://scoutparts.com/products/?view...oduct_id=13563
Maybe this is the answer!
Old 02-13-2009, 09:29 AM   #6
curly68
curly68's Avatar
Thanks for your help. I was thinking that maybe the ring that snaps over the float may be to tight. After time it causes the float to crack. It's just a pain to have to keep changing it out. I also thought that maybe the floats are cheap. Mike
Old 02-13-2009, 09:56 AM   #7
68gmsee
Active Member
68gmsee's Avatar
I bought an aftermarket one and haven't had any problems. Been in my truck for about 5 years.
Maybe the newer ones are thinner or not built the same.
68gmsee is offline   Reply With Quote
Old 02-14-2009, 08:37 AM   #8
71 super
71 super's Avatar
I have had the same problem and need to change it again. I have used GM and aftermarket and both have gone to crap as every one seems to develop a pin hole and not always near the retainer for the arm. Good to know other are having the same problem , thought it was just me.....
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
