need new fuel pump
Ok, so I'm thumbing through the Summit catalog and I'm in need of a new fuel pump for my SBC. Anyone here running one of the Holley mechanical pumps. In the Summit catalog is pn# HLY-12-327-11. It's the one that flows 110 GPH. It caught my attention because it has bigger inlet/outlet ports, 3/8", but I still need to keep the pressure down since I'm not running a regulator. I'm looking for something that won't break on me. My vehicle isn't a daily driver, but I don't want a cheap p.o.s. Any input or personal experience would be nice.
My engine is stock... trust me ;o) |
Im using the sumit brand pump...it works good, but it puts out 9 psi..so you have to use a regualtor
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
its all about the +6 inches
Looking at your signiture...I'g just go to auto zone and get a stock one wiht a life time warranty.
hehe...... the only time it was stock was before I owned it. I need the aftermarket pumps to hook up my stainless braided fuel lines.
Used to have a truck
I have used the holley mechanical pumps in the past and I have used Carter mechanical pumps for years and several different vehicles. The Carter pumps are MUCH better pumps than the Holleys. Better diaphagms, more consistent hi rpm pressure etc. Theyre about the same price. I run a carter on my truck right now that I have had since I was 15 years old ( lets just say that was over 20 years ago ) . Still runs like a champ. You can hook up braided lines to them too and the lower housing rotates to clear obstructions.
No truck :-( |
thanks..... thats the type of input i'm looking for
Hey mikep, would you know off hand what size ports the Carter pump has? Is it 1/4 or 3/8"?
1/4" NPT
No truck :-( |
ahhh, OK. Speakin softly and carryin a big stick eh?
A stock 4bbl pump will be 3/8
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
