Old 02-13-2009, 08:39 AM   #1
maxreps
hood lock
Anyone come up with a way to lock your hood, not using the locking hood pins because I really don't want to go that route cosmetically. I have a few of the cable locks for guns and was thinking of a way to secure the hood latch handle to the center upright that it's right beside. But I can't quite figure it out so it'd be easy to remove/install with the grill on.
Any ideas or successes?
maxreps is offline   Reply With Quote
Old 02-13-2009, 09:12 AM   #2
silvereagle07
silvereagle07's Avatar
Re: hood lock
I believe I've seen on here where someone modified the radiator support to house hood pins from a Pontiac Soltice. I could be wrong...
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-13-2009, 11:39 PM   #3
maxreps
Re: hood lock
that sounds interesting, I'll see if I can search on solstice.. thanks
Old 02-14-2009, 09:59 AM   #4
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Re: hood lock
I'm interested in this as well. I'm looking to put on a grill that would block the hood release.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 02-14-2009, 10:52 AM   #5
andrewmp6
Re: hood lock
Could rig up a cable style hod release like most newer cars and trucks use.Or the old redneck way chain the latch to something with a pad lock.
andrewmp6 is offline   Reply With Quote
Old 02-14-2009, 12:44 PM   #6
maxreps
Re: hood lock
GIT R DONE!!!
Old 02-16-2009, 06:14 PM   #7
silvereagle07
Re: hood lock
I worked on a Grand Marquis the other day. Maybe someone could install that hood latch on the 73-80 truck. When the latch is pulled in the car a little secondary latch rod shoots out of the grille and hides away when you close the hood. Just an idea...
Jeramy
'85 Chevy 4X4 SOLD
Old 02-16-2009, 08:10 PM   #8
sierra4x4
sierra4x4's Avatar
Re: hood lock
Why not just use a factory inside cab hood release from a late (78-80) truck?
sierra4x4 is offline   Reply With Quote
Old 02-16-2009, 08:54 PM   #9
maxreps
Re: hood lock
That is a possibility but honestly I had no clue when internal releases were put on these trucks...
Old 02-16-2009, 10:18 PM   #10
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: hood lock
I did a write up on this a while back. From what i can tell, EVERYTHING is different.
http://67-72chevytrucks.com/vboard/s...d.php?t=298856
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 02-17-2009, 01:44 AM   #11
Blazer Eagle
Re: hood lock
what i have is just a chain that locks onto the rad support, a little redneckish i guess but it works, ill take a pic tomorrow
Blazer Eagle is offline   Reply With Quote
Old 02-17-2009, 02:32 AM   #12
Pyrotechnic
Pyrotechnic's Avatar
Re: hood lock
I've got small chains that attaches to each side of the lever, and drops down each side of the center latch support. The chains are locked together under the center support which prevents you from lifting the latch. Each side of the latch had a small hole in it from the factory, so I notch the end links of the chain on the side with a hack saw, then slipped the links into the holes on the latch. Almost like the holes were there for this purpose.
I had a better idea in mind for a lock bar that will be easier to deal with when I get the chance, but I did the redneck chain method for now so I can sleep better at night.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 02-17-2009, 09:26 AM   #13
jimfulco
Re: hood lock
I also went the redneck route and used a plastic-coated steel bicycle locking cable with a loop on each end. It's wrapped around either the frame rail or the steering box, I forget which. One loop barely comes above the radiator support, and the other runs up through two of the slots on the underside of the hood, then back to the other loop, where it's padlocked. The hood will only open ~6 inches when it's locked.
jimfulco is offline   Reply With Quote
Old 02-17-2009, 11:23 AM   #14
maxreps
Re: hood lock
I think I'll do something like tha chain thing instead of swapping out all the parts needed for an inside latch setup. Any pics would be great..
I'm thinking of attaching a piece to the lever itself and making it long enough so it'll hang down to the frame/bumper area and have maybe another short piece down there then use a padlock to connect them which would leave the lock kinda hidden by the bumper.
Unlocking it would take a few more seconds but it's like insurance, "pay a little now or alot later" if a thief happens upon the truck. Yes of course if they want something they'll get it somehow but for the casual thief or troublemaker it'd be a deterrant. better than them just being able to open the hood and wreak havoc or swipe a battery/MSD box/carb/etc..
