Out of the carpool lane.
I bought a new auto tranny column shifter lever and knob. I tried forcing the knob on but couldn't get it on all the way and had to pull it back off. I figured I'd put the lever in the freezer and the knob in hot water and with some anti-seize lube, attempt to put the two together. Anyone got any better solutions?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Re: How do I install shifter knob on column shifter lever?
I think the normal process is to put the knob in hot water for a little bit and then push it on the shaft. I wouldn't use any chemicals on the shaft though.
Hollister Road Co.
You have to warm up the knob and force it on. Clamp the handle up in a vise and tap it on with a soft faced mallet
Can use dry ice on shifter and warm up knob in hot water
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Moderator
![]() Join Date: May 2007
Beat it on with a rubber mallet. Worked for me.
I ended up putting the lever in the freezer for a day and microwaving some hot water for the knob. I still had to pound the knob on but finally got it on all the way.
