Old 02-13-2009, 04:30 PM   #1
69-72
69-72's Avatar
Question 71-72 Style gas pedal
Is there any trick to adjusting the travel of the cable style gas pedals? I can't see any way to do it.
In my 72 Blazer the pedal is already on the carpet before I lay my foot on it, I have to really jam it down to get anywhere. Good for saving gas I guess but the truck don't go very fast. Anyone run into this problem before?
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 02-13-2009, 05:00 PM   #2
mrh33916
Project '67 454
mrh33916's Avatar
Re: 71-72 Style gas pedal
Bend the upper rod of the gas pedal above the hinge away from the firewall. That will raise the gas pedal and give you more travel.
mrh33916 is offline   Reply With Quote
Old 02-13-2009, 06:33 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
first, double check the throttle brackets. There should be a piece bolted to the intake where the outer cable plugs into and the inner cable comes out and hooks to the carb. On my burb that sucker kept popping off on my trip home from Washington and I could only get 1/2 throttle.
