Under hood wiring questions
I have a '72 long bed and I am replacing the engine. The wiring under the hood needs some love. Is there a harness that goes from the firewall and changes voltage regulator to internal alternator, and to HEI? I am not planning on replacing anything on the inside of the cab (yet).
Re: Under hood wiring questions
Depends on how bad your harness is. But if you check FAQ section 1 wire Alt & HEI install will guide you what to change. If you decide to have a custom wire harness that route check with GMC Pauls a vendor he has the harnesses made for how you want em.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Thanks. I'll give him a call.
Check his web site. He has prices there.
resident oilfield trash
I would really like a whole diagram for under the hood. I found one on the site but it was black and white and kind of unclear
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
#6 | |
![]() Join Date: May 2006
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#7 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#8 | |
