Old 02-13-2009, 07:54 PM   #1
rddaves54
rddaves54's Avatar
pulled engine/transmission today
I have pulled the engine and transmission today. I would like to ask if anyone knows what this bracket in the picture is for it is on the right side and above the starter? The torque converter do I need to fill it before I put it on the engine or wait until the engine and transmission are back in the truck?
I am replacing the housing seal and the front pump seal and filter. Is there anything else that needs to be replaced while I have the transmission out?
Have the Felpro ks2600 kit coming Monday and will start to replace the engine gaskets. I am thinking about timing chain and water pump not sure?
The inline filter in the picture is that normal or was the filter added later. I was thinking that a rubber hose connected the metal line to the fuel pump but now there is a filter. Is that alright?
Here are some pictures
rddaves54 is offline   Reply With Quote
Old 02-13-2009, 08:13 PM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: pulled engine/transmission today
Don't know what the bracket is.
Yes fill the converter before installing it.
Timing chain, you might as well check out since it is easy to get to.
That is an add on filter, sounds like you have a good plan!
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 02-13-2009, 08:40 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
If your going to pull the oil pan, might want to install a new oil pump while you're at it.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-13-2009, 08:55 PM   #4
theyammieguy
accepting donations
theyammieguy's Avatar
Wonder if that bracket is some sort of gaurd for tranny cooler lines.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 02-13-2009, 11:46 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you should plan on getting a new timing chain. I wouldn't bother with a new oil pump unless your oil pressure was low, but then you probably have other problems too.
If the converter is new/rebuilt, then dump a bottle of ATF in it. If you remove the old one, and put it back in the tranny, then don't bother, it has 3 or 4 in it already.
Been a while since I messed with a chevy fuel pump, you want that filter on the pump to carb side, not on the pump to tank side. nothing wrong with having it, actually a very good idea.
Old 02-13-2009, 11:55 PM   #6
Joesjunk
Joesjunk's Avatar
I have only seen those brackets on 72's with small block engines. Is yours a 72? They were on both side I believe. The only thing I can think of that they might be for is to direct air on to the exhaust manifolds to try to keep them cool??? They have a curve to them at the rear. Now thats just my guess, I have never been able to find out anything about them either. They make changing the spark plus a real pain! Most of them have been removed and thrown away.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 02-18-2009, 05:21 PM   #7
rddaves54
rddaves54's Avatar
How do I check to see if water pump is bad?
I am getting a timing chain but how would I check to see if I need to replace the gears also?
Hope to replace all these things, with seals and gaskets this weekend!!
Old 02-18-2009, 05:43 PM   #8
cdowns
cdowns's Avatar
timing chains come as a set with the gears
Old 02-18-2009, 05:52 PM   #9
NYC-10
screamin eagle
NYC-10's Avatar
might as well throw in a cam and lifters while your at it
SCREAMIN EAGLE
NYC-10 is offline   Reply With Quote
