Old 12-12-2002, 05:38 AM   #1
79Silv4x4
Workaholic
79Silv4x4's Avatar
Question Power steering problems
Now that it's getting colder I have a weird p/s problem. When I first start the truck I have no power steering for about 10 or 15 seconds and then all of a sudden it works normal. The reservoir shows to be full of fluid. The pump doesn't make any unusual noises but could it be going bad anyway? Any ideas?
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 12-12-2002, 09:14 AM   #2
BigRed
So I guess that because the resevoir is full you don't have a leak? Sounds to me like somehow you're losing pressure. But if you were losing pressure, you'd think there would be a leak involved. Guess it could be the pump, not much else I can think of.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 12-12-2002, 09:38 AM   #3
arveetek
Ultimate Diesel Dude
arveetek's Avatar
My truck is doing the same thing, only it lasts for a few minutes, until the fluid is warmed up. I'll have a little power assist when I turn the wheel at idle, but if I rev the engine up, all power assist goes away. After driving a few miles, everything is normal again.
I'm pretty sure it's the pump. Mine got low on PS fluid a while back, and I kept forgetting to add any. After topping it off, it made noise for about a week. I think I ruined my pump. Doh!!!
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's
Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's
arveetek is offline   Reply With Quote
Old 12-12-2002, 10:06 AM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
Seals are starting to go. Reason it only does it when cold is the seal expands when the fluid gets warm and stops any internal leaking of the pressure.
Easy fix, install a new pump.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 12-12-2002, 01:10 PM   #5
79Silv4x4
Workaholic
79Silv4x4's Avatar
Thanks Mike, I suspected that the pump was the problem but that was just a guess. Another project for this weekend.
1991 V1500 Subruban
Old 01-03-2003, 06:36 PM   #6
arveetek
arveetek's Avatar
Did you get your problem fixed?
The reason I ask, is that my problem was just a loose belt. It was acting strange like yours, but I never heard the belt squeal at all. The old belt was stretched, and couldn't be tightened anymore. A new belt solved my problem. I guess it was slipping most of the time, even though it never squealed.
You might just need to tighten your belt.
