02-14-2009, 09:56 AM | #1 |
AC brackets & dash issues
My 72 C-20 350 is missing the air compressor and bracket. Can anyone give me a source for a new bracket???
I installed a new circuit board (with gauges, no tach) and now the right turn signal causes the highbeam indicator light to blink!!! Anyone experienced this problem? |
02-14-2009, 10:51 AM | #2 |
Re: AC brackets & dash issues
Believe it or not I had that problem on a 71 I used to own. It would do it for a while anytime I did anything with the wiring. It would stop after I drove the truck and used the headlights. Don't ask me why. That's just what I experienced.
What brackets do you need? All of them? Since you're not a paying subscriber you can't post a want to buy ad but you can search the classifieds. There are A/C brackets on there quite often. Good luck with your search. |
02-14-2009, 11:37 AM | #3 |
2 questions:
1st: Did you switch from the 3 guage cluster (Idiot lights) to the 5 Guage cluster? If you did and didn't redo the wiring harness plug on the back of the circuit it will cause these glitches. 2nd: Welcome to the board OK I know that I said 2 but 3rd: Try searching thru the parts board, Teeitup usually has them, If not then try the vendors on this board, they can sell you the full setup
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
02-14-2009, 12:21 PM | #4 |
Old member
Did you ground the panel with the ground wire off the back? If not then your cluster will do all kinds of weird stuff.
