Old 02-14-2009, 12:28 PM   #1
67_C-30
I have a radical idea!
67_C-30's Avatar
Bouncy drop springs!
I put a set of McGaughy 2/4 drop springs on my red '69 last night, and I'm very disappointed with the ride quality in the rear. The front goes over bumps nice and smooth (better than stock) but the rear is literally worse than my C-30 was when I took the bed off. My little girl rode up the road with me to get breakfast this morning and she was being bumped out of her booster seat on the smallest of bumps. The seat belt was on the only thing holding her down! I know this cannot normal. Does anybody have any suggestions? My blue '69 is as low as this one with heated springs, and rides great. The shocks haven't been changed on either. It seemed to get somewhat better on the way home, but I don't know if I just got more used to it. I'm not talking about a little bouncing here either. The when you rock the truck, the front goes up and down easily, but the rear is stiff as rock. Again, it feels like a truck with no bed on it. I'll post pics in a little while.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-14-2009, 12:35 PM   #2
westbrookw
LET'S GO...MOUNTAINEERS
westbrookw's Avatar
Re: Bouncy drop springs!
Try changing the shock absorbers. They might be too tall for a lower suspension.
72 SWB/Step
westbrookw is offline   Reply With Quote
Old 02-14-2009, 01:05 PM   #3
67_C-30
67_C-30's Avatar
Here's some pics. In like the way it looks, just not the ride. I think I'll take the shock loose, and see if it is not as stiff. If its just shocks, that's no big deal, I'll get some on the way. Is anyone else running McGaughy's springs?
P.S. Please excuse my filthy truck, it has been raining the last days!!
My trucks
Old 02-14-2009, 01:10 PM   #4
cdowns
cdowns's Avatar
the angle that the shocks sit is a very important part of how effectivly the shocks work// sounds like you skipped over the shock relocator option and the proper dropped shocks for the application // result=poor ride quality
Old 02-14-2009, 01:13 PM   #5
westbrookw
westbrookw's Avatar
True about the shock relocator. I forgot about that. They are very easy to bottle in.
72 SWB/Step
Old 02-14-2009, 01:16 PM   #6
texanidiot25
Eat My Rust
texanidiot25's Avatar
Are those the regular rear shocks? The stock shocks probably can't handle the lowered ride height. On top of the shock angle (if I recall right, the goal is about 30* from the imaginary centerline going up), they just ain't doing their job.
I'm running 3" drop springs and some Doetch (Something like that) shocks and the truck rides great. Front can be a little bouncier than I'd expect, but I've never driven a 67-72 so I have nothing to compare to besides newer vehicles.
But it does ride better than our stock 98 GMC Jimmy, though handling is a totally different story
texanidiot25 is offline   Reply With Quote
Old 02-14-2009, 01:18 PM   #7
67_C-30
67_C-30's Avatar
Yes you're right, I did not put the shock relocators on. This problem doesn't *seem* like its shocks, though maybe it is. The springs are very very stiff. I can push on the top of the bed rail, and I can barely move it. Are you saying that you think the shock is binding somehow? I dropped my other truck a little lower than this one with changing shocks, and it does not do this. Maybe I just need to take the shock loose and see if it changes.
My trucks
Old 02-14-2009, 01:19 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
I agree with cdowns.
Use the rear shock relocators and a good set of drop shocks (front and rear). and you will be good to go. Most likely your rear shocks are just trying to "pivot" on the mounts, instead of compressing.
Keith
Convert to disc brakes.
Old 02-14-2009, 01:29 PM   #9
texanidiot25
Eat My Rust
If the springs are stiffer, than the stock shocks don't have enough dampening to control the bounce of the stiffer shocks. Thus, when you hit a bump and the spring compress and then rebounds, the shock cannot slow that rebound motion down and the spring continues to bounce.
Old 02-14-2009, 01:38 PM   #10
71swb4x4
71swb4x4's Avatar
I agree, it's probably the shocks. They are at a horrible angle, and they are probably about bottomed out anyway. So, when you hit a bump, your shocks can't compress anymore, and therefore they are not letting the coil springs do any of the work. To test that theory, unhook the shocks and drive it down the block. I am willing to bet the ride will be much better.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-14-2009, 01:38 PM   #11
67_C-30
67_C-30's Avatar
You guys are exactly right, it is the shocks -except its not a rebound problem, the shocks are actually bottoming out on the inside. I just took them off and the truck actually dropped down a little more. The spring actually springs now. I put the shocks on last night when the suspension was hanging down some, so I didn't know they were doing this. I guess my other truck has another brand shock or something, because it doesn't bounce one bit and rides great. My experience with the other truck is why I thought I could get away without the drop shocks and relocators for awhile. These shocks are only about a year old, and I was going to try to get get some service out of them. I guess I'll stick on one of my non-lowered trucks! Thanks guys!
My trucks
Old 02-14-2009, 01:41 PM   #12
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I just installed a set of (McGauhey's) 4" rear drop springs on a 70 2WD Blazer and the ride is smooth as a babies butt. However I also used lowering shocks, shock relocation kit, and adjustible panhard bar.
Your stock height shocks are probably close to being bottomed out. So even though they are swinging more than they are compressing, they are still bottoming out. Like others have said, you need a shock relocator kit and a set of 4" drop shocks. I would also step up and buy an adjustible panhard bar. It won't improve the quality of the ride, but it will allow you to recenter the rear end. The result of which will save your tires and improve the handling. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 02-14-2009, 01:42 PM   #13
Classic Heartbeat
I see that I posted a little late.. Glad you got it figured out. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 02-14-2009, 01:45 PM   #14
LONGHAIR
I would have to agree with most of what has been said. It looks to me like the shocks are "limiting" the upward travel of the wheel, in effect becoming bump stops. Shorter shocks and a more verticle mounting position are in order.
My main disagreement is with the term "bouncy"...Bouncy is soft and un-regulated by a shock absorber. You seem to be talking about "stiff", which may bounce you in the seat because of the way older truck seats were designed. The seat was basically part of the "suspension". It softened the stiffness of the truck by suspending the driver seperately.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-14-2009, 02:01 PM   #15
67_C-30
67_C-30's Avatar
Yeah, you are actually right. I'm was the one doing the bouncing!
My trucks
Old 02-14-2009, 02:56 PM   #16
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Good info to know! Thanks C-30 for getting bounced around!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-14-2009, 03:25 PM   #17
67_C-30
67_C-30's Avatar
Uss speshal peeple aulways hav too lern tha harred wayy!!
My trucks
Old 02-14-2009, 04:22 PM   #18
powell72
powell72's Avatar
My wife's truck has the same problem, we have not done the relocator brackets yet and the shocks are completely bottomed out, so the rear is all spring, very bouncy.
BTW, the new ride height looks great! Wash that truck!
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 02-14-2009, 08:07 PM   #19
67_C-30
67_C-30's Avatar
Thanks Chris! I love the front, but that rear still needs to come down just tad, so I'm going to make a set of 1" and 1.5" blocks so I can tweak it in.
I couldn't stand the suspense, so went out in the boneyard out back and grabbed a set of old GM spiral stock shocks off of a parts and put them on. It rides wonderful! Even with worn out old shocks, it handles and rides great. I just made an order for a set of drop shocks and relocators. I am also going to make an adjustable panhard bar at work this upcoming week. I can't wait to see how it rides with all the right stuff on there.
My trucks
Old 02-14-2009, 08:13 PM   #20
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
I know it's bouncy right now but it looks great even dirty !! Bob
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 02-14-2009, 08:17 PM   #21
texanidiot25
Eat My Rust
If these springs are brand new, give them some time to settle in. They'll drop down a bit more once broken in.
Old 02-14-2009, 10:08 PM   #22
k5hart
k5hart's Avatar
I agree whole completely on the shock relacators. It made a huge difference on my blazer even with the stock shocks. It was pretty amazing the difference!
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
