Old 02-14-2009, 02:37 PM   #1
beautimus
beautimus's Avatar
ultimate liner in cab !!!!!
just got my cab back from having ultimate liner sprayed on the floor and underneath the bottom of the cab. color is a little darker than in the pics.
i wanted to have this done before paint so i could bolt it back in place
and do the paint and body work as i go. yeee haw !!! (can you tell that i am a little excited ?)
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 02-14-2009, 02:39 PM   #2
beautimus
beautimus's Avatar
Re: ultimate liner in cab !!!!!
one more
Old 02-14-2009, 02:42 PM   #3
leddzepp
Moderator
leddzepp's Avatar
looks awesome!
leddzepp is offline   Reply With Quote
Old 02-14-2009, 02:50 PM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Looks great!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-14-2009, 03:00 PM   #5
kamikazekyle05
kamikazekyle05's Avatar
That looks great, how much did it cost? Any pics of underneath the cab?
kamikazekyle05 is offline   Reply With Quote
Old 02-14-2009, 03:07 PM   #6
big_al_71
big_al_71's Avatar
thats cool!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-14-2009, 03:31 PM   #7
67_C-30
I have a radical idea!
67_C-30's Avatar
Very nice. I may need to do that to my C-30 along with the Dynamat I bought to make sure the diesel doesn't sound like its in the cab with me!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-14-2009, 03:50 PM   #8
72armyswbtruck
72armyswbtruck's Avatar
I was gonna do the same thing to my 3/4 ton 4x4, help with rust and corrosion control.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 02-14-2009, 04:41 PM   #9
thirdstreettito
Resident of Here
I have to do that with my 84, it horrible not being able to hear my radio going 80. All the tires, wind, rattling, engine, exhaust sounds...
~Bradley~
Miss having a truck
Old 02-14-2009, 05:30 PM   #10
OhioDan
OhioDan's Avatar
The guy that painted mine used the same thing when he painted the cab. Didn't know it came in colors?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 02-14-2009, 09:57 PM   #11
beautimus
beautimus's Avatar
no pics of the underside of the floor yet. my homemade cab dolly makes it impossible to get a decent pic, but i could see it well enough while the whole thing was up on the trailer to tell you that it looks just as good underneath.
i will try yo get pics when i lift the cab up to put it back on the frame.
truck outfitters and supply in tuscaloosa charged about 700 to do what you see in the pics plus the bottom all the way from the back of the cab up to the seam where the floor meets the firewall at about a 45 degree angle.
this after noon i used dupli color spray in bed liner from wallmart to do the verticle part of the firewall on the outside. it took 2 cans at about 7 bucks a can. i could have had the ultimate liner stuff sprayed on there but since it is a rubbery product, i didn't want to risk it melting down and catching fire.
the duplicolor stuff is more of a paint based product. i am going to do the back side of the dash and up high on the inside of the firewall tomorrow.
it should take about 2 more cans. Then its on to bolting this thing down and starting the body work and paint.
tony
Old 02-14-2009, 10:21 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Looks nice!
Just a question... As mentioned by 67 C-30 it is used for a sound barrier, but does this also help to limit heat inside the cab?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-15-2009, 01:19 AM   #13
texanidiot25
Eat My Rust
texanidiot25's Avatar
They typically do, as the liner material doesn't conduct heat like metal does.
My truck has a thin lining of something. Doesn't do too much, but the radio takes care of that on the freeway, even though it's a 65 mph truck
texanidiot25 is offline   Reply With Quote
Old 02-15-2009, 01:49 AM   #14
beautimus
beautimus's Avatar
yes, this was done for several reasons. sound deadening, insulation, waterproofing and since i had to use a flux core welder to do extensive repairs on the florr pan, rockers, cab corners etc. the liner material seals any pin holes that may have been missed. i glassed in all the seams before it was sprayed in just to make doubly sure that i got everything.
tony
Old 02-15-2009, 01:59 AM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Sounds like you will have a solid cab when you finish everything. Thanks for the info, and best of luck with the rest of the build!
-Nate
Old 02-15-2009, 08:47 AM   #16
Your diesel is a Silverado and came with the 6.2 sound proofing.Just imagine the motor in an old tin can cab.
Old 02-15-2009, 11:19 AM   #17
pmpski_1
pmpski_1's Avatar
What else are going to lay down over that? Dynamat? Carpet? Etc?
pmpski_1 is offline   Reply With Quote
Old 02-15-2009, 01:26 PM   #18
cdowns
cdowns's Avatar
looks nice//BUT its really not very effective for insullation and if the plans are for putting a product lilike dynamat over it i wonder how well and how long the stuff will stick to it// duct tape doesnt stick very well or very long to the lineXliner i have in the bed of my silverado/// padded insullation stuck very well to the lizard skin ceramic stuff i used in my last project
Old 02-15-2009, 01:26 PM   #19
fastom
That's right, it's Copper!!
fastom's Avatar
Great idea!!
fastom is offline   Reply With Quote
Old 02-15-2009, 03:28 PM   #20
BarryB
BarryB's Avatar
Hey guys, I am a distributor for a industrial liner product, You can spray it at home with a typical air compressor with the gun, I can get for you. If theres enough interest from the board I will become a vendor here so you guys can get it reasonablly from me. The stuff I distribute, can be color matched to your vehicle, and is better than linex, rhino, or any other industrial spray liner.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 02-15-2009, 04:06 PM   #21
beautimus
beautimus's Avatar
Talking Re: ultimate liner in cab !!!!!
cdowns
for insulating value, i think it will help. but i don't see it as being as good as a product intended for that pupose. then again, inside temps were never a problem for me. this thing has air and vent windows and a rear sliding window.
plus i run the heater in summer anyway, (cold natured)
i don't plan on using dynomat unless its still too loud inside, i will put the carpet with its padding down and see. this stuff has a rubbery surface to it,
rather than the non skid sand paper like texture that linex and others have, so sticking dynomat to it shouldn't be a problem, if i opt to do so.
my goal for this thing is to be so quiet inside, that all you hear inside at idle is the cooling fan chopping air
Old 03-23-2012, 12:19 AM   #22
beautimus
beautimus's Avatar
ttt
Old 03-23-2012, 11:40 AM   #23
MrSchaeferPants
MrSchaeferPants's Avatar
80 , try 60 Think I'm missing every rubber grommet in my firewall and the one the fuel tank breather thing goes through the cab floor, D/S vent window can't fully close, and I'm wondering about all my window seals. Can you say wind tunnel
I'd like to see what you're results are for the liner as far as noise, but by the looks of it it'll be a while huh. Definitly on my to do list, good job.
68 GMC C2500 - 305 V6 - 4spd
MrSchaeferPants is offline   Reply With Quote
Old 03-23-2012, 11:52 AM   #24
67cheby
67cheby
67cheby's Avatar
nice, i am doing the same thing on mine , i have done the underneath and as soon as i am done with all of the inside fab i am doing the floor and the full firewall to keep out the heat !
67cheby is offline   Reply With Quote
