02-14-2009, 05:40 PM | #1 |
Champagne Taste on Beer Budget
6 Cylinder Power Steering Setup
Looking for pictures of how you guy have your power steering pump mounted.
I have the pump and all the brackets but not sure how they will all fit. Specially since I will be running an aftermarket Intake and headers. Thanks in advance!
Coming Soon: Project 1970 Country Truck |
02-14-2009, 06:40 PM | #2 |
Active Member
Re: 6 Cylinder Power Steering Setup
Let me know if you need another angle.
02-14-2009, 06:43 PM | #3 |
Active Member
02-14-2009, 08:30 PM | #4 |
Good Pics!
Thanks a lot 68gmsee!!
02-14-2009, 10:25 PM | #5 |
Tot Roddin'
Tallcountry... can you list out the parts required for the addition of PS to your 250? I'm throwing around the idea of adding PS to my '69 but am unsure on the parts I would need.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
02-14-2009, 11:56 PM | #6 |
Active Member
If you just need a pic of the parts required, check my post above (#3). There's a picture of all the parts needed. Best bet is to try to find a 6 cylinder vehicle in the 70's. I got mine off an El Camino, but have see them in Chevy Novas of that vintage also. Try to find one with a non integrated head.
02-15-2009, 12:08 AM | #7 |
Member #1049
Here's a couple of pics off of a 72 6...
02-15-2009, 12:42 AM | #8 |
72... will post up Pics of what I have that will give you a good idea what I have to work with since they are not attached to the engine yet.
How's that?
02-15-2009, 12:48 AM | #9 |
Tot Roddin'
That will be awesome! That's what I was looking for, a spread out shot of all the required pieces.
Thanks TC, 68 and Livrat.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 02-15-2009 at 12:49 AM. |
02-15-2009, 12:58 AM | #10 |
67-72 parts collector,…
Nate,... if you look at the P/S "pump" bracket,... you can see the difference in just these two styles, shown here. The best bet would be to buy a complete set up off of the same engine. I'll keep an eye out for a set for your 250 6-cylinder.
I'm also collecting P/S photos on my laptop.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-15-2009 at 12:59 AM. |
02-15-2009, 01:06 AM | #11 |
Tot Roddin'
Now.... to add to this, has anyone ever seen a motor with a smog setup and powersteering???
Thanks for the info Keith, I will take a look at the pics further and then compare them to TC's pics he's going to post.
02-15-2009, 01:19 PM | #12 |
Okay well this is not really a list of parts but more of a picture of what I have and hope it's enough to get it going.
Notice in the background is the power steering gear box I bought from teeitup. Got the power steering pump and all brackets for free since I bought a 12-bolt rear end with 5x5 bolt pattern from a salvage yard in Texas. I hope this helps a little bit. Will take more pictures once I have cleaned and painted all the parts. There is one more bracket that is not pictured, but like I said will take more once all are assembled.
02-15-2009, 02:08 PM | #13 |
Member #1049
Your main lower mounting bracket looks to be off of an "intregal head" 250. (although not positive)... the non integral and integral head mounting bracket do not interchange.. here are pic of a complete integral head setup..
I also have a non integral head lower bracket that I will get pictures of later today and post them for you.. |
02-15-2009, 04:32 PM | #14 |
Member #1049
here are a couple of pictures of the non intregral head main mounting bracket..
02-15-2009, 05:49 PM | #15 |
Yeah those look totally different from mine.
Looks like I may have the wrong brackets then. Rats!
02-15-2009, 09:10 PM | #16 |
Tot Roddin'
Thanks for getting the pics TC, and hopefully those brackets will still work out for you.
