Old 02-14-2009, 07:30 PM   #1
b-rad
back sliding glass
how do u take the window out of the frame
b-rad is offline   Reply With Quote
Old 02-15-2009, 09:58 AM   #2
b-rad
Re: back sliding glass
bump
Old 02-15-2009, 10:48 AM   #3
68gmsee
Active Member
68gmsee's Avatar
I've never removed glass before but I am also thinking of removing the sliding glass on mine to have the cab sandblasted.
In my case, since I had the window installed almost 20 years ago, I will just cut the rubber to remove it and have the glass shop reinstall if I decided to keep it.
You might want to try the body/paint forum to see if those guys have an easy method to do it. I hear it requires strong string or flexible thin wire, wooden wedge, soapy water and best done with two people.
68gmsee is offline   Reply With Quote
Old 02-15-2009, 02:57 PM   #4
b-rad
no see i have it off the truck but the glass is in a frame and i can not get it out it
Old 02-15-2009, 03:04 PM   #5
mr48chev
mr48chev's Avatar
Is the frame held together with screws or riviets that can be removed to separate the top and bottom halves? It's been a long time since I have looked at one of those and every one is a bit different from one manufacture to an other.
