02-14-2009, 08:18 PM | #1 |
Air Lockers ?
Anyone ever put these on a two wheel drive ? My old '69 gets in some deep sand sometimes . Just wondered if locking both rear wheels makes much difference .
02-15-2009, 10:17 AM | #2 |
Re: Air Lockers ?
I have one in the front of a 4x4. They can be run in the rear as well,but because of their expense, are often not.The reason for the ability to lock and unlock them is with the front axle, you cannot leave it locked all the time,as the truck would not want to turn. You only lock it when you need maximum traction. For the rear, you can run a posi. It has gears or clutches that allow for the different speed that each wheel will have gong around corners. I have used "Lok Rite" diffs in the rear of trucks that originally did not have a posi, as they do not require complete disassembly of the rear gears. Having power to both wheels will definitely help. Wider rear tires and an onboard air compressor will also help a lot, as you can air the tires down to 10-15 psi or so to get more contact, then air the tires back up before getting back on the road.
02-15-2009, 10:51 AM | #3 |
Re: Air Lockers ?
Detroit TruTrac are Limited slip good for front or back.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
02-15-2009, 11:49 AM | #4 |
Re: Air Lockers ?
Thanks !
02-15-2009, 12:49 PM | #5 |
Re: Air Lockers ?
I run them in my 4x4 willys jeep and love them.They are a locker so if you have it on pavement and take a sarp turn you will scuff one of the wheel around and get a tire screech as well,this could be hard on your axles . They are purfect for dirt roads and off road use for sure.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 02-15-2009 at 12:50 PM. |
02-15-2009, 01:21 PM | #6 |
Eat My Rust
Re: Air Lockers ?
02-15-2009, 07:22 PM | #7 |
Re: Air Lockers ?
They are Limited slips most of the Power will go to the tire with the traction. They will not lockup completly like a Detroit Locker that is both wheels all the time. I did not want a full locker in My CJ 5 because of the weather here and I gto pretty good prices for them on Ebay. I have not tried them out yet just getting done with putting all back together.
Ron
02-15-2009, 07:47 PM | #8 |
Re: Air Lockers ?
I had an ARB in my jeep and it worked well. Don't see why it wouldn't work just the same in a 2wd.
If it were up to me though, I'd go with a posi for a non-offroad rig |
