Old 02-14-2009, 10:33 PM   #1
pritch
pritch's Avatar
Bad rust. Not what I wanted to see
The good news is this is all of it. The bad news is, it seems really bad to me. I will have my work cut out for me. I knew there was some on the floor corners, but the dash sent me for a loop. Lucky thing I have a replacement dash.
I'm not in a real big hurry to fix this, I plan on doing the chassis first, then the drive train, then bodywork last.
One question I do have though, I know there are patch panels for floors, but are 'Burb floors different from truck floors, and are Panel floors different from 'Burbs?
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 02-14-2009, 10:48 PM   #2
fine69
fine69's Avatar
Re: Bad rust. Not what I wanted to see
I hope i can make you feel better.
THAT AIN'T NOTHIN'.
That is only 3 or 4 hours total work. And it would be sweet.
Cut it out, weld some patches in. POR-15 it.
Sandblast the dash. The epoxy paint it.
OR scuff off the rust with a wire wheel. Then POR-15 it. Good as new.
NO way would i sweat that little bit.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 02-14-2009, 11:58 PM   #3
Grapdawg
Driven a 72
Grapdawg's Avatar
yep very much like the work i did on my floor. It wasnt that big of a job. I actually used some scrap metal i got from a freind and just cut out all the rot on my truck, then welded a patch over all area's then put alittle fiberglass over the seams and rust inhibitor, primed then used undercoating on it.
1996 GMC JIMMY
1972 CHEVY C10 LWB
My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729
Grapdawg is offline   Reply With Quote
Old 02-15-2009, 12:00 AM   #4
texanidiot25
Eat My Rust
texanidiot25's Avatar
I'll gladly trade you my cab.
texanidiot25 is offline   Reply With Quote
Old 02-15-2009, 12:08 AM   #5
phipp13
THE DAMN YANKEE
phipp13's Avatar
i had the same problem. check out my build thread. i have some pretty good pictures of how i cut it out and repaired it. i got rid of all the rust,
http://www.67-72chevytrucks.com/vboa...d.php?t=318731
phipp13 is offline   Reply With Quote
Old 02-15-2009, 12:27 AM   #6
pritch
pritch's Avatar
Well, sounds like it's not gonna be that bad. Like I said, I'm going to concentrate on my chassis first, but maybe I'll dabble with this a little in the mean time. I guess overall I am fairly lucky in the rust department. Whoever did the undercoating did a nice job. The majority of the underneath is still pristine once the undercoating is scraped off
'68 Panel
'68 C-10
Ol' Green
