02-14-2009, 10:44 PM | #1 |
Sb 400 club
Bodymen, painters, panal replacers help me out.
I put doors, front fenders and hood on my 77 today. They are all used GM stuff. Well ...... My gaps are horendus!! nothing has an even gap. Both doors rub when opening. I need some advice, tips trick for this stuff. I reused the shims that where on the fenders I took off.
This is my first time doing this and I can't seem to get this stuff right. Left it all losse and tightened it up. ... I will go take some pics now! Pass dooor sticking outside the fender.....
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out Last edited by 84 400; 02-14-2009 at 11:15 PM. |
02-14-2009, 11:20 PM | #2 |
Re: Bodymen, painters, panal eplacers help me out.
Lots of trial and error my friend. start with the doors and try to get them aligned with the rockers and get a uniform gap at the back of the cab, then move forward and try to align your fenders to your doors
02-15-2009, 12:48 AM | #3 |
I never could get the fender and hood to line up on my 77 Bonanza. I tried pretty hard but gave up. The trucks of that era just were not set up to be that great looking off the line. Some were better than others, but they were just trucks. I bought mine new off the lot in 77 for $5500. So, not the big ticket computer CNC jobs they are making now. It can be done, but with lots of work and know how. Those guys on the TV shows make it look easy, but I bet they edit-out miles of tape.
02-15-2009, 05:31 AM | #4 | |
Go Hard or Go Home!
75 short wide 350, some mods, scare the piss outta ya quick. 2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick. Some day's, it's just not worth chewing through the restraints................................ |
02-15-2009, 06:27 AM | #5 |
The way i would do it is get the doors to fit the cab everything centered and your happy then move on to the fenders.Yes open up the bolt holes on the fenders it takes time to get panel fitment prefect so take your time don't give up tell your happy.The gap spacing is a easy fix don't worry about that tell you get everything fitting good.The gaps you can gentally grind some off or weld on some.The spot where the fender top meets the cap you'll have to add on it to make it look god right there.
02-15-2009, 10:04 AM | #6 |
I have replaced basically the same parts as they all seem to rust in the same places. As said before it is a lot of trial and error and also the spacer washers may need to be different then the original (more or less).
02-15-2009, 10:21 AM | #7 |
Weekend Warrior
I agree with everyone else - align your doors and then move on to the fenders. If the Used parts are Factory GM then you shouldn't have to open up the holes - just play with the shims.
You'll probably get the gaps to be even and 1/2 way decent, but they will never look like the "ball bearing" gaps of today - to get those you would have to cut and weld fenders, hoods, doors etc etc. - that's a ton of work
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
02-15-2009, 09:03 PM | #8 |
I don't think these pills work
just takes time and paitence. i'm interested in seeing the whole truck though looks like 15 different shades of green going on there.
SQUARE84 90 SUBURBAN |
