02-15-2009, 02:56 AM | #1 |
Rear Gas Tank Conversion AND Hidden Hitch Anyone?
Just wondering if its do-able for both a Blazer/Burb tank and a hidden type hitch to be installed on the same truck.
Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 Last edited by Ford Assassin; 02-15-2009 at 02:19 PM. |
02-15-2009, 02:58 AM | #2 |
Re: Rear Gas Tank Conversion AND Hidden Hitch Anyone?
brothers has a nice gas tank relocation kit I think its like 230.00 including the sending unit mounting hardware
02-15-2009, 08:25 AM | #3 |
I think I read on here sometime back that it is do-able......
I have a Hidden-Hitch also that I have not installed yet. I am also thinking about the rear tank with it.
1997 GMC Sierra Ext 1965 Mustang |
02-15-2009, 10:05 AM | #4 |
ive done a few, and it is possible....matter of fact, its streight forward, nothing hard to do...
02-15-2009, 10:18 AM | #5 |
I’m going to be installing a Blazer gas tank and was looking for a hitch that would work, talked to Wes at Classic Heartbeat http://www.classicheartbeat.com/default.htm he supplied me with a shorter hitch to clear the tank and its receiver will exit just behind the license plate on the bumper. I haven’t installed the gas tank or the hitch yet but it appears that it will work for me. If I remember correctly from what Wes said the hitch is for a suburban and is shorter to clear the tank. Suggest you talk to Wes about the installation your planning on doing and I bet he can supply what you need.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544 |
02-15-2009, 01:20 PM | #6 | ||
I need a setup that will allow the Blazer/Burb tank AND still allow me to use the hidden hitch. Quote:
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
02-15-2009, 01:23 PM | #7 |
Moderator
I live down the street from Brothers, and according to them, it is not possible with the hidden hitch/Blazer tank combination.
02-15-2009, 01:25 PM | #8 |
ECE had them for pickups, suburbans and blazers. Obviously the suburbans and blazers are set up for the rear gas tank.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
02-15-2009, 01:29 PM | #9 |
You do realize that neither one of those pictures have a bumper/roll pan on them at the time right? Either one would cover those hitches.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
02-15-2009, 01:38 PM | #10 | ||
But who knows, I've been wrong before.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 Last edited by Ford Assassin; 02-15-2009 at 01:39 PM. |
02-15-2009, 01:41 PM | #11 |
Moderator
02-15-2009, 02:10 PM | #12 |
both pics are the "hidden" type hitches....
02-15-2009, 03:11 PM | #13 |
Wes at ClassicHeartbeat had a Blazer tank and hidden hitch under the truck he called the "Garden Truck" a drop dead beautiful 3/4 ton 4X4. I saw the truck first hand and the install looked great and made the decision easy for me to do the same when I redo the 71. I'm not sure how well it will work on a shortie though.
02-15-2009, 03:27 PM | #14 |
ECE hidden hitch will work with Blazer tank. Just did it on the 68 K20 we are finishing
Mike Redpath |
