Old 02-15-2009, 07:22 AM   #1
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Windows won't roll down....Help!
The windows on my '62 are extremely difficult to roll up or down.
It helps if I lift the window, crank a little bit, wiggle the window, shake some more...
I need a little advice before I tear into the doors.
How do the handles come off?
They look to be different than my '69.
I'm hoping for a clean,lubricate,re-assemble type fix.
Am I looking at that or something else entirely.
A bit of "been there, done that" help goes a long way.
Thanks, Todd
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 02-15-2009, 07:45 AM   #2
welsh kev
welsh kev's Avatar
Re: Windows won't roll down....Help!
Looks pretty similar to my 63. Door and window handles are located by grub screws recessed into the handles. Remove these, also the arm-rest which is located by two screws. Remove screws from panel surround, you then have access to the regulator mechanism.
I had this problem on mine; basically it's wear, tear and weather which ruins the strips. Don't be tempted to leave it, I wiggled my window once too often and broke the spot-welds which hold the channel to the regulator. Be very careful when removing anything inside, it's a good idea to photograph things before you strip them if you haven't got a workshop manual.
I would renew all the weather-strip if I were you, not expensive and worth doing.
63 GMC fleetside, 305 V6; over-built, over thirsty and over here!
welsh kev is offline   Reply With Quote
