Old 12-12-2002, 01:47 PM   #1
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Post Fusing , the HEI and Electric choke
Just installed a 5 amp fuse ,feeding the HEI and the electric choke on the Edelbrock .
Just was wondering if this was over kill.
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 12-12-2002, 06:42 PM   #2
fatfords
fatfords's Avatar
Did the carb come with any instructions for the electric choke circuit? Generally, that is a pretty low currrent item.
I looked at a couple of wiring diagrams I have laying around for late 70's/early 80's Chevy trucks and same year Camaros. Almost all of them use a 12 guage wire to power the HEI fed off of a 10 amp ignition fuse. Some also power idiot lights, but they should not be on under normal conditions. Fusing the HEI is a good idea, but I would consider increasing the amperage of the entire circuit.
Remember, size the fuse to protect the wiring first and the load second.
Kent
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 12-12-2002, 06:53 PM   #3
MikeB
MikeB's Avatar
My HEI and Edlebrock carb choke have been wired to the same circuit for many years. Don't know my fuse size, though. If you haven't already done it, make sure you get rid of the resistance wire that was used with the points ditributor. The HEI likes 12 volts or more.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-12-2002, 08:17 PM   #4
Bill72BB
Bill72BB's Avatar
I've been using 12 gauge wire for the Hei ,and the choke . thanks for the input ,will probably switch to a 10 amp next time I'm at the part's store.
BILL
Member DUF Club
Old 12-13-2002, 01:25 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I had to have a new engine wiring harness, and ordered it from M&H Electrical Fabricators, in Sante Fe Springs, CA. I asked for it to be modified for the HEI that I have. I includes the leads for an electric choke heater, as well as the oil pressure sending unit, neither of which my truck has. You can get them at wiringharness.com.
Member Nr. 2770
Old 12-13-2002, 03:02 PM   #6
ScottH
ScottH's Avatar
Does the HEI wire have to be fused? I've seen it run to the fuse box where it's connected to a terminal directly. Is this looking for trouble? Should an inline fuse be used?
Thanks.
ScottH is offline   Reply With Quote
Old 12-13-2002, 03:37 PM   #7
Bill72BB
Bill72BB's Avatar
ScottH
I ran it for awhile unfused ,just being cautious .
BILL
Member DUF Club
Old 12-13-2002, 03:46 PM   #8
fatfords
fatfords's Avatar
ScottH,
It is good practice to protect the wire that is providing power with a fuse. Without knowing anything about how your truck is wired, I can't tell you if you really need to add an in-line fuse. I can tell you that even the "unfused ignition" terminals on the fuse block are fed by a 12 guage wire with a fusible link at the battery connection, so it is still protected.
Good Luck,
Kent
'05 GMC crew cab
Old 12-13-2002, 05:17 PM   #9
SCOTI
SCOTI's Avatar
Cheap Insurance
I wired my 68 250 6cyl HEI w/12 guage wire & ran it directly to the fuse block under the dash. It worked fine this way for 2yrs. About a month ago, I couldn't get it to start in the morning. I thought I just flooded & when I checked it again that evening it started right up. Since then it has turned over just fine but taken longer to start. I figured this was because of no choke & recent cold weather (for Dallas anyway) but when leaving work one day it died & wouldn't restart. I found what was left of the solderless connector still stuck to the fuse block & very charred. The wire had no wear spots so I'm not sure what caused the meltdown. I replaced it w/10 guage wire w/20 amp inline blade style fuse for security. I'm rewiring a mustang @ home right now for a guy because the main ignition wire caught the rest of the underdash wires on fire & I know I don't want that happening to my truck.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
