Under Construction
PS hose ? for serpentine conversion
I read throught the FAQ on the serp conversion, and I was wondering how did you all handle the power steering hoses, as the older PS pump have the flare style end connectors, and the '94 ps pump has the end connections that has the o-ring to seal.
I am thinking i will have to have one made up at the hydraulic shop, but wanted to see what other have done. Thanks Heath
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Re: PS hose ? for serpentine conversion
Just change the fitting on the back of the PS pump with your old one and your old hoses will fit fine.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Under Construction
I didnt notice the fittings were interchangable, probably because i got frustrated, i will go take a look.
Thanks Larry!
Be careful taking it out that you don't lose anything.
Under Construction
will do, thanks again!
