![]() Join Date: Dec 2008
tilt column rebuild
I want to rebuild my tilt column myself. I need bearing part numbers and where to buy them. My internet searches didn't help much.
Re: tilt column rebuild
i need these too..
page 51 has a $29 bearing and the plastic retainer but i'm not sure if it's what I need. http://www.scribd.com/full/5722345?a...jcbazlklxtunnw
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
67101 & 02 you may need the retainer too. But that looks like the parts you need. The one I did wasn't in too bad of shape. I packed the bearing in bearing grease. Most play was found in the retaining torque screws
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
where's the best place to find those
Moderator
![]() Join Date: May 2007
I think there was a thread a while back showing the process of getting to and re-tightening the retaining screws.
Exploded view
and some instructions that another member posted. Hardest part I had was the retaining pins that require a machine screw inserted into them and a slide hammer to pop them out...
Its always something!
Are there any special tools needed to take one of these apart?
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed ![]() ![]() Member of the patina club |
Nope, I have a box of parts to prove it...
Like I said, the retaining pins in the pictures mention about using a socket, washer and machine screw to pull them out. That would work or a slide hammer and the screw.
I have a tilt column that the wheel will only turn 90 degrees and stops. Is this the knuckle or something else? Thanks
Found the bearings at www.brotherstrucks.com under dash components.
Moderator
www.truckandcarshop.com has them also
#13 | |
I assume that it's not in a truck, if so then I think it would have to be the knuckle part. I have a spare one but the shaft was cut off so it's only good for parts.
#14 |
I've been looking for parts for while. For MSGROSS, you mention you have a parts column. Does it still have the shift lever detent spring (the one that puts the tension on the shift lever)? I need one and have been unable to find one anywhere. Cnut
#15 |
That knuckle would really have to be screwed up to only turn 90 degrees.
Hardest part was figuring out I had to pull the side pins out to slide the collar off. I used a pr vice grips on a screw and a mallet.
#16 |
![]() ![]() Join Date: Dec 1999
CarQuest auto parts has the tool for removing the side pins.
Part # 19940 Steering wheel pivot pin remover.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
#17 |
now you tell me!!!
#18 |
I've got one of those, I am going to shave the shift lever off anyway. Send me your address and i'll drop it in an envelope for you...
#19 |
![]() Join Date: Jul 2007
I have a question about the top column sleeve (collar that the turn signal lever goes through). I understand you need a puller but when I used mine it didn't want to move. Is there anything else on the inside of that collar that needs to be compressed so it will slide off easier??
It's Not Rust, It's Patina!! 1967 ![]() 2008 ![]() |
#20 |
nope, it should slide off easily, just remove the flasher knob... or if it's a red flasher knob then pull the entire turn signal mechanism first. I have only taken a few apart but they come right off for me.
#21 |
Thanks guys for the invaluable info., saved to favorites for future ref.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#22 |
PITbut
#23 |
#24 | |
The proper tool for this job is Kent moore #J-22551, and for the reinstallation of the bowl use Kent Moore #J-22549, it is highly unlikely you will successfully complete either the removal or installation of the bowl without these special service tools. Consult the service manual for the 1971 c10 for the entire procedure, I will provide a link to a thread that will point you to a site so you can download the .pdf version below. http://67-72chevytrucks.com/vboard/s...d.php?t=558016 Regards. Brian |
#25 | |
![]() Join Date: May 2002
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
