02-15-2009, 08:29 PM | #1 |
temp gauge question
i just picked up a 70 custom 10, anyway i had to take the intake manifold off to do soem work, after putting it all back together i started the car and noticed my temp gauge was bouncing very fast back and forth from cold to hot, i looked at the green wire inder the hood and it was striped in spots so i replaced a couple feet of wire, anyway not the gauge wont move off cold, is there any test i can do like grounding the wire or anything to find out where the problem may be?
02-15-2009, 09:39 PM | #2 |
Re: temp gauge question
same problem here, does your green wire have a plug that goes into the sensor? or how is it plugged in?
02-15-2009, 10:00 PM | #3 |
Check your connections sounds like your butt splice isn't crimped good.
02-15-2009, 10:12 PM | #4 |
can you elaborate on that, (Check your connections sounds like your butt splice isn't crimped good) where is said butt splice?
02-15-2009, 10:17 PM | #5 |
(i looked at the green wire inder the hood and it was striped in spots so i replaced a couple feet of wire,)
In order to replace a couple of feet of wire a butt splice would be necessary. SS68 Did this answer your Question? Last edited by Cunit69; 02-15-2009 at 11:39 PM. |
02-16-2009, 11:09 AM | #6 |
Old member
Where the wire connects to the sendor on the motor and where you tied the new wire into the old wire check for good connections.
02-16-2009, 12:49 PM | #7 |
Msgt USAF Ret
http://www.6066gmcguy.org/Electrical-02.htm
scroll down to the water temp gauge
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-16-2009, 12:57 PM | #8 |
Old Skool Club
If the wire (green, encased in a heat shield) comes into contact with the engine, the guage needle will move everytime it grounds out. I once had a problem with my wiring and the needle bounced from hot to cold so fast I thought it would break off.....as I bounced down the road.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
