02-15-2009, 10:02 PM | #1 |
whats the best way
Whats the best way to remove the tranny crossmember? Can you unbolt it?
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011 Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 |
02-15-2009, 10:09 PM | #2 |
Junior Member
Re: whats the best way
You have to unbolt it. If I recall correctly, it's got 4 bolts on each side (2 on the upper part of the frame and two on the lower) for a total of 8. If the crossmember hasn't been out before they may be so covered with crud you can't even see them. You'll need a wrench on both the bolt head and the nut on the other end. Once all the bolts are out, just tap on the front of one side with a hammer, and on the back of the other side, and it'll come out.
69 GMC Sierra 1500 Custom 68 Camaro SS 18 GMC Sierra SLT Living the dream |
02-15-2009, 10:16 PM | #3 |
laying low
Mitch if I remember right your truck was a standard trans truck. ? If so you are no doubt referring to the crossmember under the bellhousing part of the standard trans. That one should be riveted in. That pretty much calls for a cutting torch or hammer and chisel.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
02-15-2009, 10:19 PM | #4 |
Just removed the crossmember for my 4speed, it sits closer to the engine than the automatic tranny crossmembers. It had rivets. I used a die grinder and a 3" cutting wheel to cut the rivets. Lotta fun Couldn't get to the side of the rivets near the firewall so I cut them into pizza slices and chiseled them out.
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) Last edited by 9teen69; 02-15-2009 at 10:24 PM. |
02-15-2009, 10:44 PM | #5 |
yeah i guess this will be fun, oh boy what a time i'll have haha thanks guys
