Old 02-16-2009, 12:23 PM   #1
mdazb
mdazb's Avatar
Power steering box
I Plan on converting to P/S. A guy I bought some parts for about a year ago thew in this box and pump for nothing. My question is, Is there a way I can make sure it will fit before I start to tear down? ie: cast #, Fitting type etc... It has a cast # 7802644 Are 4x4 and 2wd boxes the same?
72 C10 SWB 350 Work in progress
98 HD Fatboy
09 HD Heritage Softail
05 Honda Element
mdazb is offline   Reply With Quote
Old 02-16-2009, 04:48 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: Power steering box
2wd and 4wd are different in the way the pitman arm points. I don't believe they can be swapped from one to the other. As long is it is pre 1978 or so,the fittings will be standard, not metric. I have swapped a few boxes from early- mid 70's trucks onto 68-72 trucks with no problems. I also helped swap a 1984 box with metric fittings onto a 1968 that had a 1997 Vortec 350 engine swapped in with the 1997 serpentine front drive.
WIDESIDE72 is offline   Reply With Quote
Old 02-16-2009, 06:30 PM   #3
mdazb
mdazb's Avatar
How can you tell if it's "pre-1978"?
98 HD Fatboy
05 Honda Element
Old 02-16-2009, 07:06 PM   #4
norwegianc10
What kind of fittings were used before and after 78? I am working on hydroboost setup on a 67.
67 c10 Short Step 350/th400 daily driver
69 Camaro work in progress
norwegianc10 is offline   Reply With Quote
