81 chevy truck with headers and A/C
Hello all , been mainly a reader, now working on a 81 chevy lwb. It had a leaky 305 so I yanked it out and installed a 350 I had in another truck. I went with my old headers from my other truck but the A/C bracket wont fit now, it was curved to fit the stock exhaust manifold. Guess I could do a little welding to make it work but was wondering any simpler ideas. It has the small compressor mounted in front. Will post picks when I figure that out .
Thanks Warren Last edited by Cruzin81; 02-16-2009 at 02:02 PM. Reason: adding text |
Parts and more parts
Re: 81 chevy truck with headers and A/C
I took the A/C bracket on my truck and my Son's truck and used the old exhaust manifold bolt for the front header bolt. I made some spacers out of stainless steel and used that to take up the space out to where the original A/C bracket sets. I also chopped some of the original A/C bracketry off and eliminated the top mounting bolt on the back of the A/C compressor. That cleaned up the truck quite a bit and makes it easier to m ount the headers.
Thanks for the info, do you have any pics of your bracket setup? I took the altenator bracket of my t-bucket that is used foe the altenator with headers and after looking at that believe I can just clearnce inside about 1/8" on each side and should work.
Well I forgot about the space the original manifold took up, was moking the brackets up and seen the space. Might be able to make a bracket to weld onto the current bracket and the welded piece would bolt around the headers.
Any other Ideas? Last edited by Cruzin81; 02-16-2009 at 08:27 PM. Reason: adding text |
#5 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=304940 |
I found another bracket I'm going to cut it and see how that goes , thanks for the info. Yall have some cool trucks, hopefully I'll be able to add mine to a build project.
I cut the stock bracket... and used a spacer. Pretty easy..It could have been done a bit cleaner, but it wasnt for a show truck and only had a sawzall at the time.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 02-18-2009 at 06:02 PM. |
Thanks Prerunner, thats what I needed a few pictures, I understand a little better that way. Does it hold up all the weight with just 1 bolt with no problem? Could I get a pic of the whole setup, with how the brackets go together ? Thought I could remember it seemed pretty straight forward when I took them off.
Thanks again warren |
