Old 02-16-2009, 02:53 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Question Leak in my Cab
I have a leak behind the glove box. There's some rust under the over hang part just above the heater/ac box. Hard to explain, check out the pic. I have no idea how I'm going to get to it to cut out the rust. Last time I had the cowl off it seemed solid.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-16-2009, 03:09 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Leak in my Cab
Sin,
take a look at the drip lip, under the hood, that's just behind the heater box. I just imagine it's coming from there by where the rust is at in your pic. I actually came out to the garage just to look at the area, but since I don't have a/c, mine's a bit different.
is it just surface rust or has it got some depth?
unfortunately, you may have to pull the cowl and the heater/ac box off the firewall to rule out where your getting the water infiltration.
sorry, not a great answer. hopefully someone else can chime in.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 02-16-2009, 03:17 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Re: Leak in my Cab
Hey Doug. The rust is about a 3" square. It's pretty bad. It's above the heater box though. I'm thinking it's leaking from somewhere around the cowl somehow.
Beat it to fit,
Old 02-16-2009, 03:28 PM   #4
tcb-1
tcb-1's Avatar
Re: Leak in my Cab
Sin,
I really think you should pull the cowl. I will guarantee you a 6 pack of Schlitz (yeah I'm cheap) that it's the drip lip under the hood or maybe a cowl screw that's allowing water in. those freaking body seals are notorious for rust in those areas.
hate to say it, but your going to have to remove a few items so that the picture may be clearer. start with the cowl since it's the easiest. if you were closer I'd be over to help wrench.......
Doug
Old 02-16-2009, 03:31 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Re: Leak in my Cab
How would I seal a cowl screw? I think that may be the culprit.
Beat it to fit,
Old 02-16-2009, 03:43 PM   #6
tcb-1
tcb-1's Avatar
Re: Leak in my Cab
easiest way would be to install the screw like normal, then put a dab of silicone over it.
Doug
Old 02-16-2009, 03:47 PM   #7
Re: Leak in my Cab
Take your cowl cover off.There`s abody seam where the windshield post meets the cowl that leaks when the seal goes bad.It can rust out if not noticed in time.
Old 02-16-2009, 04:10 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
Re: Leak in my Cab
Thanks for the help guys. I gotta wait a couple of days for it to quit raining, then I'll pull the cowl and see what's up.
Beat it to fit,
Old 02-16-2009, 05:33 PM   #9
tcb-1
tcb-1's Avatar
Re: Leak in my Cab
it's raining AGAIN in LA? that's kind of rare, isn't it Sin??
Doug
Old 02-16-2009, 05:35 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
Re: Leak in my Cab
It's our version of Winter. LOL
Beat it to fit,
