Old 02-16-2009, 06:30 PM   #1
truckintexas
Sending Unit Question
Can anyone tell me if a 0-85 ohm sending unit will operate the factory fuel gauge on my 72 chevy?? I seem to remember that ours are rated at 0-90 ohms. Is the 0-85 ohms close enough to function properly? Thanks.
truckintexas is offline   Reply With Quote
Old 02-16-2009, 07:14 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Sending Unit Question
I guess you would just have to try it. You wouldn't think 5 ohms would make that much difference but I suppose it could make it read wrong. I'm not good with the electronics math....
LockDoc
Leon
Old 02-16-2009, 09:44 PM   #3
Andy4639
Old member
Andy4639's Avatar
I know I have a 1993 Suburban operating my 1971 factory gauge. What OHM'S it is I have no idea. It's GM though!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-16-2009, 09:48 PM   #4
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
The Burb sender is 0-90 Ohms. The sender you have will work. Although, when you fill up it wont show 100% full. It will show correct when empty.
--Josh
Old 02-17-2009, 12:00 AM   #5
truckintexas
Smile Re: Sending Unit Question
Ahhhhhh, I get it. The gauge will never show full, because the max ohms will always be 5 short. I would imagine it would be real close. Probably just a bit under "F" instead of a bit over.
Thanks for yout input,
Michael
Old 02-17-2009, 07:10 AM   #6
Larry S
Larry S's Avatar
Does anyone know how many ohms a 1996 silverado sender is?
Larry S is offline   Reply With Quote
Old 02-17-2009, 10:58 AM   #7
Andy4639
Old member
Andy4639's Avatar
My gauge works fine. It is dead on the money. I installed about 12 years ago now and it reads full.
I have the whole tank out of the 1993 suburban.
