02-16-2009, 07:29 PM | #1 |
starting relay question?
where is the relay that controls the starter sylinoid?
when i go to start mine which we just did YEHAAAAAAAAAAAA. sometimes the starter does not turn over. i know it is not the sylinoid we have a push button on it to start it. i got tired of holding the key and it sometimes not working... but anyway. is the sylinoid under the dash?? that is where i think it is haven't really had time to chase it down. has anyone had this problem before? part numbers??? all help appreciated. thanks |
02-16-2009, 09:01 PM | #2 |
Re: starting relay question?
Chevy doesn't use a relay. The low-amperage side of the solenoid energizes the high-amperage side. There's a copper disc in there that makes the contact and it can get carbon buildup on it with age. You can take the solenoid apart and use a file to clean it or you might want to replace your solenoid.
02-16-2009, 09:24 PM | #3 |
so could my switch be bad?
i have a got wire with a push button in line and it starts it just fine with the sylinoid on the side of the starter. does the hot go from the switch to the sylinoid? i thought there was a relay inbetween. |
02-17-2009, 12:16 AM | #4 |
Hot goes from the starter switch to the S terminal on the solenoid.
You can test the solenoid by jumpering from the positive cable to the start pole of the solenoid (make sure the key is off). |
02-22-2009, 12:39 PM | #5 |
its all about the +6 inches
your ignition switch and/or plug is probably worn/melted
02-22-2009, 03:16 PM | #6 |
leaning toward the switch. i have one in the dash PO lost key and one hanging that i am using now (probly no good). either going to go with new one or i am thinking of a hidden push button switch under dash somewhere that will require the key to be in and turned to the on position.
BE NICE IT PAYS IN THE END. |
