Old 02-16-2009, 10:25 PM   #1
tazztoy
original rims please!!
i'm trying to figure out what rims these 3/4 trucks came with or were op'ed with. untill a couple days ago i thught they were all 16" split rims but i'm finding many different things and sizes. i'm looking at 3/4 ton eight lugs. found many non-split 16'' found a few narrow (7.50) (8.25) 16.5 one i found was running a wide rim 12.00-16.5 mud&snow and i've seen 2 with 7.00-17 mud&snow. now all these rims look the same on the inside, no white spokes. were these odballs op's or early after markets?
'71 K-20 6.2, 5spd, 4x4, longhorn, FACTORY cab lights, project.
'07 cummins/6spd
'79 3500 454/400 4x4, dana 60,
'84 toy 4.6/700r4 cust lift, 35"a/t, welded r, locker f
'99 F250 7.3/zf6 spd reg/long, edge, local fab ext. (wifes)
'79 Bronco 351/c-6 13" w/44 ground hawgs (wifes)
tazztoy is offline   Reply With Quote
Old 02-16-2009, 11:03 PM   #2
kookykrispy
The Early Chevy Van Man
Re: original rims please!!
My '72 C20 is all original. It has 16.5 while steel wheels with chrome caps. I do not think they are split rims and they seem pretty narrow... probably 7.5" sounds about right.
64 Chevy Van
65 GMC Handi-Van
99 2500 silverado 4x4 ext cab
kookykrispy is offline   Reply With Quote
Old 02-16-2009, 11:17 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
most that I've seen were with 16.5 X 7 solid rims. There were a lot sold with the 16 inch split rims, but they need to be thrown away. (most tire shops won't let you in the door with them, and some states won't pass you on an inspection with them) There was also an optional 16.5X9 inch that are commonly called camper wheels by the uninformed. They are hard to find, and worth some coin.
Old 02-17-2009, 03:48 AM   #4
stllookn
Saving 1 truck at a time!
stllookn's Avatar
tazztoy, Many sizes...no white spokes though...LOL! As an example rim width standard was 5.25 or 7-17.5 according to the Chevrolet truck brochure. Optional rims could be 16, 16.5, 17, 17.5, and 19.5. Rim width could have been 5, 6.0, 6.75, or 8.25. One tons also had 5.5 in rim width. The widest tire option was 10-16.5 on a 8.25 inch wide rim...example shown in the pic. The big after-market wheel and tire combination back in the day were the 9.75 x 16.5 rims with 12.5 x 33 x 16.5 tires.
31 x 10.50 x 16.5 on 8.25 wide stock wheel
6.5 x 16 on split rim
33 x 12.5 x 16.5 on 9.75 alloy and
33 x 12.5 x 16.5 on 9.75 steel aftermarket wheel.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 02-17-2009, 03:58 AM   #5
stllookn
stllookn's Avatar
Here's a better pic of the stock 8.25 wheel combination with 31 x 10.5 x 16.5 up front and 33 x 12.5 x 16.5 on the back. The rims are 8.25 inch wide...the widest offered by the General in this time period.
Old 02-17-2009, 11:02 AM   #6
tazztoy
thanks a ton, I'll have to see if i can get a hold of the 16.5 set with 12.00on them.. the 17 are a stock option then cool, but where can i find replacement tires? 7.00-17? i looked for a couple hours last night and couldn't find any on the net.
'07 cummins/6spd
Old 02-17-2009, 12:44 PM   #7
stllookn
stllookn's Avatar
Here's the ones I love. 9.75 x 16.5 wheels with clips for the old school hubcaps. They stopped making these in 1968. I have one set that I have powder coated that will go on my 1968 Longhorn. These are aftermarket Firestone wheels...some guys called them "Camper" wheels because back in the day guys would run them on the back of the 3/4 and 1-ton trucks when they hauled their campers.
Before and after pics...Kelsey Hayes also manufactured these I believe. They measure 9.75 inches at the bead and 11.00 inches flange to flange. Yes..they will work on the front of a 2x4 Chevy 3/4 ton.
Old 02-17-2009, 01:06 PM   #8
mr48chev
mr48chev's Avatar
You might consider looking into having a set made by one of the aftermarket steel wheel shops. A set of 16-8 or 8.5 steel rims that will take a stock hubcap and have the offset you want shouldn't be that hard to get and not be that much more expensive than refinishing a set of used rims.
tires
As the other guys said, most tire shops will no longer work on split rims and some won't allow them in the shop at all. On some of the odd sizes that were usually only ordered by the railroad or some farmers and ranchers because they liked the tall skinny tires, tires may be difficult to find.
Old 02-17-2009, 03:08 PM   #9
longhorn70gmc
longhorn70gmc's Avatar
You don't say, I think I have two of those off of the longhorn in the back yard. I just refused to get rid of them. Thanks Andy!!!!
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 02-18-2009, 11:02 PM   #10
factorystock
factorystock's Avatar
The rim size depended on what tires were ordered when new.67 thru 68 3/4 tons carried over alot of the older sizes 16, 17, 17.5 19.5. From 69-72, only the 16" 2 piece and 16.5" one piece were regular options. Split rims were 6" and used 7.50-16 tires. Narrow 16.5" rims(6.75") were used on 8.00-16.5 tires,wider (8.25")rims were used on 9.50-16.5 tires and extra wide camper rims(9.75") used 12-16.5" tires, mainly on rear axle.
factorystock is offline   Reply With Quote
Old 02-23-2009, 09:18 PM   #11
PortHeadlight
PortHeadlight's Avatar
I've got a set of 9.75 x 16.5 old school alloy rims like the one in the picture with like 3 lug nuts :-) I want to put these all around on a 3/4 ton 1970 2x4 Suburban. No lift! Will 33 x 12.5 x 16.5 fit in there ok without any rubbing/modifications? If not, what size tire will work? Any suggestions? THanks!
PortHeadlight is offline   Reply With Quote
Old 02-23-2009, 09:43 PM   #12
CG
BlahBlahBlah
I had a 72 C20 with those size tires and wheels. They fit but it was kinda close. Sure looked beefy though.
Old 02-23-2009, 10:56 PM   #13
bigdon-70blazer
Did they make some of these caps in 4WD style with hole in them for the front? I have a set of the 8.25 X 16.5 with the clips, 2 are NOS! I prefer painted to chrome. Anybody know where I can get some!
bigdon-70blazer is offline   Reply With Quote
Old 02-23-2009, 11:04 PM   #14
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: original rims please!!
Mine has the 9.50 tire/wheel option..
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
